Dicota Anti-Glare filter 3H for iPhone 12/12 Pro, self-adhesive
Quicklinx: G1QQWS00 Mfr#: D70347
Product Range: DICOTA
£9.21 ex VAT
£11.05 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Touch capable
  • Silicone layer on the back allows for full-surface adhesion
  • A clear view at all times
  • Accurate colour reproduction
  • Reduces reflections and fingerprints
  • High mechanical resilience
  • Attaches easily without forming bubbles
  • No residue when removed
DICOTA - screen protector for mobile phone
Screen protector - film
Intended For
Mobile phone
Protection
Scratch-resistant, fingerprint-proof, anti-glare, anti-reflective
Product Material
PET film (3H)
6.458 cm 13.979 cm
Thickness
0.155 mm
Transparent
Apple iPhone 12, 12 Pro
Intended For
Mobile phone
Protection
Product Material
PET film (3H)
6.458 cm
13.979 cm
Thickness
0.155 mm
Transparent
Brand: Dicota
