Dicota Anti-Glare filter 3H for iPad Mini 6 (8.3), self-adhesive
Quicklinx: GX3RWS00 Mfr#: D70525
£12.39 ex VAT
£14.86 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Touch capable
  • Silicone layer on the back allows for full-surface adhesion
  • A clear view at all times
  • Accurate colour reproduction
  • Reduces reflections and fingerprints
  • High scratch resistance
  • Attaches easily without forming bubbles
  • No residue when removed
DICOTA - screen protector for tablet - anti-glare filter, 3H, self-adhesive
Screen protector - film
Intended For
Tablet
Screen Size Compatibility
8.3"
Protection
Scratch-resistant, fingerprint-proof, anti-glare
Product Material
PET
19.15 cm 13.1 cm
Thickness
0.155 mm
10 g
Transparent
Apple iPad mini (6th generation)
Intended For
Tablet
8.3"
Protection
Product Material
PET
19.15 cm
13.1 cm
10 g
Thickness
0.155 mm
Transparent
Brand: Dicota
