The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
- Touch capable
- Silicone layer on the back allows for full-surface adhesion
- A clear view at all times
- Accurate colour reproduction
- Reduces reflections and fingerprints
- High scratch resistance
- Attaches easily without forming bubbles
- No residue when removed
- DICOTA - screen protector for tablet - anti-glare filter, 3H, self-adhesive
- Product Type
- Screen protector - film
- Intended For
- Tablet
- Screen Size Compatibility
- 8.3"
- Protection
- Scratch-resistant, fingerprint-proof, anti-glare
- Product Material
- PET
- 19.15 cm 13.1 cm
- Thickness
- 0.155 mm
- 10 g
- Transparent
- 2-year warranty
- Designed For
- Apple iPad mini (6th generation)
- Product Type
- Intended For
- Tablet
- 8.3"
- Protection
- Product Material
- PET
- 19.15 cm
- 13.1 cm
- 10 g
- Thickness
- 0.155 mm
- Transparent
- 2-year warranty
- Designed For
