Dicota Anti-glare filter 3H for iPad 10.9 2022 (10th Generation), self-adhesive
Quicklinx: HG5CWS00 Mfr#: D70641
£16.47 ex VAT
£19.76 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - screen protector for tablet - anti-glare filter, 3H, self-adhesive
Screen protector - film
Intended For
Tablet
Installation Type
Removable - adhesive
Protection
Scratch-resistant, fingerprint-proof, anti-glare
Coating
Anti-reflective
Package Content
Screen protector, cleaning wipe
Product Material
PET film (3H)
24.4 cm 17.5 cm
Thickness
0.15 mm
10 g
Apple 10.9-inch iPad (10th generation)
Intended For
Tablet
Installation Type
Protection
Package Content
Product Material
PET film (3H)
Coating
Anti-reflective
24.4 cm
17.5 cm
10 g
Thickness
0.15 mm
Brand: Dicota
