Dicota Anti-glare filter 3H for iMac 24 (2021), self-adhesive
Quicklinx: HG2JWS00 Mfr#: D70655
£50.40 ex VAT
£60.48 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA - display anti-glare filter - 3H
Display anti-glare filter - 3H
Installation Type
Adhesive
Image Colour Disclaimer
The displayed product image may be a different colour
Product Material
PET
54.15 cm 31.55 cm
40 g
Anti-reflective, fingerprint-resistant coating, 3H hard-coating, bubble-free installation, silicone layer back, touch capable, clear view, accurate colour reproduction, residue free
Apple iMac (24 in)
Product Material
PET
54.15 cm
31.55 cm
Thickness
0.15 mm
40 g
Finish
Matte
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Apple iMac (24 in)
Brand: Dicota
