Dicota Anti-Glare filter 3H for HP Elitebook x360 830 G5/G6, self-adhesive
Quicklinx: GDSNWS00 Mfr#: D70365
£19.81 ex VAT
£23.77 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook privacy filter - anti-glare 3H
Notebook privacy filter - anti-glare 3H
Installation Type
Removable - adhesive
Transparent
Product Material
PET
30.58 cm 21.05 cm
20 g
Anti-reflective, bubble-free installation, fingerprint-proof, silicone layer back, touch capable
HP EliteBook x360 830 G5 Notebook, 830 G6 Notebook
Product Material
PET
30.58 cm
21.05 cm
Thickness
0.155 mm
20 g
Transparent
Display Filter
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
