The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
- DICOTA - notebook anti-glare filter
- Product Type
- Notebook anti-glare filter
- Installation Type
- Adhesive
- Transparent
- Product Material
- PET
- 31.5 cm 19.15 cm
- Anti-glare, 3H hard-coating, bubble-free installation, self-adhesive, silicone layer back, touch capable
- 2-year warranty
- Designed For
- HP EliteBook x360 1040 G7 Notebook, 1040 G8 Notebook
- Product Type
- Product Material
- PET
- 31.5 cm
- 19.15 cm
- Thickness
- 0.155 mm
- Transparent
Display Filter
- Installation Type
- Adhesive
- Scratch Resistant
- Limited warranty: - 2 years
- Designed For
