Dicota Anti-Glare Filter 3H For HP EliteBook 1030 G1 Self-Adhesive
Quicklinx: FS6BWS00 Mfr#: D31661
£19.81 ex VAT
£23.77 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook privacy filter
Notebook privacy filter
Installation Type
Adhesive
Transparent
Product Material
Silicone, PET
30.4 cm 19.3 cm
100 g
Anti-glare, scratch-resistant
Product Material
Silicone, PET
30.4 cm
19.3 cm
Thickness
0.155 mm
100 g
Transparent
Display Filter
Installation Type
Adhesive
Brand: Dicota
