Dicota Anti-glare filter 3H for HP Elite x2 G4 self-adhesive
Quicklinx: G33WWS00 Mfr#: D70211
£17.34 ex VAT
£20.80 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Installation Type
Removable - adhesive
Transparent
Product Material
PET
28.35 cm 20.95 cm
20 g
Anti-glare, anti-reflective, fingerprint-resistant coating, 3H hard-coating, silicone layer back, high mechanical resilience, full-surface adhesion, touch capable
HP Elite x2 G4
Product Material
PET
28.35 cm
20.95 cm
Thickness
0.155 mm
20 g
Transparent
Display Filter
Installation Type
Scratch Resistant
Limited warranty: - 2 years
HP Elite x2 G4
Brand: Dicota
