Dicota Anti-glare filter 3H for HP Dragonfly Folio G3 2-in-1, self-adhesive
Quicklinx: HG58WS00 Mfr#: D70627
£20.12 ex VAT
£24.14 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with advanced laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-glare filter - 3H
Notebook anti-glare filter - 3H
Installation Type
Adhesive
Product Material
PET
29.15 cm 21 cm
20 g
Anti-glare, anti-reflective, easy-to-remove, 3H hard-coating, bubble-free installation, scratch-resistant, self-adhesive, fingerprint-proof, silicone layer back, touch capable
HP Dragonfly Folio G3 Notebook
Product Material
PET
29.15 cm
21 cm
Thickness
0.15 mm
20 g
Display Filter
Installation Type
Adhesive
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
