Dicota Anti-Glare Filter 3H For Getac T800 Self-Adhesive
Quicklinx: FS65WS00 Mfr#: D70080
£10.05 ex VAT
£12.06 inc VAT
The Dicota protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Durable material
    Constructed from robust PET film, this screen protector offers reliable strength and resilience against wear and tear.
  • Effective protection
    Designed for tablets, it provides coverage against scratches and scuffs, ensuring the device remains in excellent condition.
  • Enhanced visibility
    The anti-glare feature minimizes reflections, allowing for comfortable viewing even under direct light, enhancing usability on-the-go.
  • Easy installation
    The film can be precisely applied without bubbles, providing seamless integration with your tablet for an unobstructed view.
DICOTA - screen protector for tablet
Screen protector - film
Intended For
Tablet
Protection
Scratch-resistant, fingerprint-proof, anti-glare
Product Material
PET film (3H)
19.48 cm 13.7 cm
10 g
Transparent
Getac T800
Intended For
Tablet
Protection
Product Material
PET film (3H)
19.48 cm
13.7 cm
10 g
Transparent
Getac T800
Brand: Dicota
