Dicota Anti-glare filter 3H for DELL Latitude 9330 2-in-1, self-adhesive
Quicklinx: HQHYWS00 Mfr#: D70800
£18.45 ex VAT
£22.14 inc VAT
Discover the perfect companion for your notebook with DICOTA's anti-glare filter. Designed to enhance your viewing experience, this filter features a scratch-resistant surface, ensuring your screen stays in excellent condition. Its anti-glare and anti-reflection coatings significantly reduce glare and reflections, allowing for better visibility in bright environments. Additionally, the fingerprint-resistant coating keeps your screen clean and clear. The self-adhesive silicone layer ensures easy application and removal, making it convenient to maintain. Whether you're working outdoors or in brightly lit areas, this filter provides the protection and clarity you need.
  • Enhanced durability
    Equipped with a scratch-resistant surface, this notebook anti-glare filter is designed to withstand daily wear and tear, ensuring your device remains pristine.
  • Improved screen visibility
    Featuring anti-glare and anti-reflection coatings, this filter minimizes screen glare and reflections, offering a clearer view under various lighting conditions.
  • Touch compatibility
    With its touch-capable design, this filter allows for uninterrupted touchscreen functionality, ensuring smooth interaction with your device.
  • Easy application
    Thanks to its self-adhesive silicone layer back, the filter can be easily applied and removed without leaving any residue, offering a hassle-free experience.
DICOTA - notebook anti-glare filter - 3H
Notebook anti-glare filter - 3H
Installation Type
Removable - adhesive
Transparent
Product Material
PET
29.35 cm 19.1 cm
14 g
Scratch-resistant, fingerprint-resistant coating, anti-reflection coating, anti-glare, self-adhesive, touch capable, silicone layer back
Dell Latitude 9330 2-in-1
Product Material
PET
29.35 cm
19.1 cm
Thickness
0.15 mm
14 g
Transparent
Display Filter
Installation Type
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
