Dicota Anti-Glare filter 3H for DELL Latitude 7320 detachable, self-adhesive
Quicklinx: GQL1WS00 Mfr#: D70438
£16.96 ex VAT
£20.35 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Durable material
    Constructed with PET film (3H), this filter is built to resist scratches and maintain its integrity over time.
  • Easy installation
    The adhesive installation process is designed for bubble-free application, making it simple to attach and remove without leaving residues.
  • Enhanced visibility
    Anti-glare and anti-reflective features work together to minimize reflections, ensuring optimal visibility in various lighting conditions.
  • Flexible use
    Removable and self-adhesive, it allows for convenient usage around different environments and can be taken off when not needed.
  • Touch capability
    This filter retains touch functionality, enabling users to efficiently interact with their touchscreen devices.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Installation Type
Removable - adhesive
Transparent
Product Material
PET film (3H)
28.4 cm 20.3 cm
20 g
Anti-glare, anti-reflective, fingerprint-resistant coating, bubble-free installation, self-adhesive, silicone layer back, high mechanical resilience, touch capable
Dell Latitude 7320 Detachable
Product Material
PET film (3H)
28.4 cm
20.3 cm
Thickness
0.155 mm
20 g
Transparent
Display Filter
Installation Type
Scratch Resistant
Frameless
Limited warranty: - 2 years
Brand: Dicota
