Dicota Anti-Glare Filter 3H For Dell Latitude 7200 2-In-1 Self-Adhesive
Quicklinx: FS5YWS00 Mfr#: D70179
£18.86 ex VAT
£22.63 inc VAT
The anti-glare filters reduce reflections caused by sunlight and protect the screen from scratches. The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue.
DICOTA Anti-Glare Filter 3H - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
28.7 cm 20.4 cm
10 g
Anti-reflective, self-adhesive, silicone layer back, high mechanical resilience, touch capable
Dell Latitude 7200 2-in-1
Product Material
PET
28.7 cm
20.4 cm
Thickness
0.155 mm
10 g
Transparent
Display Filter
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
