Dicota Anti-Glare Filter 3H For Dell Latitude 5289 Self-Adhesive
Quicklinx: FS5WWS00 Mfr#: D31442
£18.58 ex VAT
£22.29 inc VAT
The DICOTA screen protector takes care of various tasks: it protects the screen against scratches, reduces annoying fingerprint marks and is easy to attach. In addition, the high-resolution screen becomes anti-reflective, ensuring clear visibility. The screen protector is your first choice. The filter reduces reflections caused by sunlight and protects the screen from scratches. The film adheres directly to the screen thanks to the use of a silicon layer.
  • Effective glare reduction
    This notebook anti-glare filter minimizes reflections and distractions from ambient light, allowing users to focus on their work without interruption.
  • Durable scratch resistance
    Constructed from high-quality PET material, the filter resists scratches and helps maintain the integrity of the notebook screen over time.
  • Simple self-adhesive application
    The self-adhesive property ensures a hassle-free installation process, allowing users to easily apply or remove the filter without leaving residue behind.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Product Material
PET
30.006 cm 19.19 cm
14 g
Self-adhesive
Dell Latitude 5289 2-In-1
Product Material
PET
30.006 cm
19.19 cm
Thickness
1 mm
14 g
Display Filter
Scratch Resistant
Self-adhesive
Limited warranty: - 2 years
Brand: Dicota
