Dicota Anti-Glare Filter 3H For Dell Latitude 11 (517X) Self-Adhesive
Quicklinx: FS5SWS00 Mfr#: D31374
£14.86 ex VAT
£17.83 inc VAT
The DICOTA protective film fulfills a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
DICOTA - notebook anti-glare filter
Notebook anti-glare filter
Transparent
Product Material
PET
27.43 cm 17.08 cm
10 g
Anti-glare, anti-reflective, fingerprint-resistant coating, bubble-free installation, self-adhesive
Dell Latitude 5175 2-in-1, 5179
Product Material
PET
27.43 cm
17.08 cm
Thickness
0.155 mm
10 g
Transparent
Display Filter
Scratch Resistant
Limited warranty: - 2 years
Brand: Dicota
