Dicota Anti-glare filter 3H for Apple iPad Pro 13.0 2024, self-adhesive
Quicklinx: HV42WS00 Mfr#: D70862
£19.20 ex VAT
£23.04 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Effective Anti-Glare Coating
    The screen protector features an anti-glare coating that minimizes reflections and enhances your viewing experience in various lighting conditions.
  • Scratch and Fingerprint Resistance
    Constructed from durable PET film, this protector is designed to resist scratches and fingerprints, keeping your tablet display clean and clear.
  • Self-Adhesive Application
    The self-adhesive film allows for a hassle-free installation, ensuring a secure fit on your tablet without bubbles or residue.
DICOTA - screen protector for tablet - 3H, self-adhesive
Screen protector - film
Intended For
Tablet
Protection
Scratch-resistant, fingerprint-resistant
Coating
Anti-glare
Package Content
Screen protective film, cleaning wipe
Product Material
PET film (3H)
21.16 cm 27.76 cm
Thickness
0.15 mm
10 g
Transparent
Apple 13-inch iPad Pro (M4)
Intended For
Tablet
Protection
Package Content
Product Material
PET film (3H)
Coating
Anti-glare
21.16 cm
27.76 cm
10 g
Thickness
0.15 mm
Transparent
Brand: Dicota
