Dicota Anti-glare filter 3H for Apple iPad Pro 11.0 2024, self-adhesive
Quicklinx: HV3SWS00 Mfr#: D70853
£16.47 ex VAT
£19.76 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Durable material
    The screen protector is made from high-quality PET film, which provides a solid barrier against daily wear and tear.
  • Effective protection
    With its scratch-resistant and fingerprint-resistant features, this protector ensures that the tablet screen remains clear and functional.
  • User-friendly application
    The self-adhesive film allows for a simple and bubble-free installation process, making it convenient for users.
  • Glare reduction
    The anti-glare coating minimizes reflections, enhancing the viewing experience under various lighting conditions.
DICOTA - screen protector for tablet - 3H, self-adhesive
Screen protector - film
Intended For
Tablet
Protection
Scratch-resistant, fingerprint-resistant
Coating
Anti-glare
Package Content
Screen protective film, cleaning wipe
Product Material
PET film (3H)
17.35 cm 24.57 cm
Thickness
0.15 mm
10 g
Transparent
Apple 11-inch iPad Pro M4 Wi-Fi, M4 Wi-Fi + Cellular
Intended For
Tablet
Protection
Package Content
Product Material
PET film (3H)
Coating
Anti-glare
17.35 cm
24.57 cm
10 g
Thickness
0.15 mm
Transparent
Brand: Dicota
