Dicota Anti-glare filter 3H for Apple iPad Air 13.0 2024, self-adhesive
Quicklinx: HV3HWS00 Mfr#: D70844
£19.07 ex VAT
£22.88 inc VAT
The DICOTA protective film fulfils a variety of functions: it protects the display from scratches, reduces annoying fingerprints and is easy to attach. It also provides a non-reflective coating for high-resolution displays, guaranteeing a clear view. This makes the anti-glare film the number one choice for you. The film adheres directly to the full surface of the display thanks to the use of a silicone layer.
The anti-glare filters are made with the latest laser cutters and cut to the right size with maximum reliability. The filter is extremely easy to fit. It takes just a few seconds for it to adhere to the full surface of the display and begin carrying out its functions. No more scratches, fewer annoying fingerprints and a high degree of anti-reflection coating for your display. It can be easily removed at any time without leaving any residue. This is a quality German product you can rely on, and is simple and handy to use.
  • Protective Design
    The protector features a scratch-resistant construction that helps keep your tablet's display free from unsightly marks, extending the life of the device.
  • Enhanced Viewing Experience
    The anti-glare coating reduces reflections, enabling comfortable screen use in bright environments and making it easier to view your content.
  • Easy Self-Adhesive Application
    The self-adhesive feature allows for a bubble-free installation, ensuring that the screen protector adheres smoothly to the device without hassle.
  • Fingerprint Resistance
    With its fingerprint-resistant surface, the protector maintains a clear display by minimizing smudges and oils from daily use.
  • Complete Installation Kit
    The package includes a cleaning wipe, providing everything needed for a seamless and effective application of the screen protector.
DICOTA - screen protector for tablet - 3H, self-adhesive
Screen protector - film
Intended For
Tablet
Protection
Scratch-resistant, fingerprint-resistant
Coating
Anti-glare
Package Content
Screen protective film, cleaning wipe
Product Material
PET film (3H)
21.1 cm 27.66 cm
Thickness
0.15 mm
10 g
Transparent
Apple 13-inch iPad Air (M2, M3)
Intended For
Tablet
Protection
Package Content
Product Material
PET film (3H)
Coating
Anti-glare
21.1 cm
27.66 cm
10 g
Thickness
0.15 mm
Transparent
Brand: Dicota
