The effective cushioning made of High-Density Foam (HDF) protects the notebook safely inside the case and the notebook strap keeps it in place. In addition to the notebook Alu Briefcase also has room for power supply unit, replacement battery or other items int the cable bag that comes with the bag. Additional mobile accessories can be stored in the workstation and documents can be placed in the document compartment in the case lid. The removable shoulder strap also provides for comfortable transport.
- DICOTA Alu Briefcase 17.3 - notebook carrying case
- Product Type
- Notebook carrying case
- Grey
- Notebook Compatibility
- 17.3"
- High-Density Foam (HDF)
- Carrying Strap
- Hand grip
- Product Type
- 17.3"
- Notebook Compatibility Dimensions
- 42 cm x 29.5 cm x 4.5 cm
- Carrying Strap
- Hand grip
- Grey
