Dicota Active Stylus Premium - Black
Quicklinx: FS1PWS00 Mfr#: D31260
33 In Stock
£29.25 ex VAT
£35.10 inc VAT
Smartphones, tablets and convertibles are part of your daily lives, both for business and leisure. With the Dicota Stylus Premium you can operate your touchscreen even more precisely and hence increase your mobile efficiency. The slim and lightweight input pen fits nicely in your hand while the grip surface gives optimum hold. Follow your intuition and operate touch applications with familiar movements. Writing, drawing and navigating with high precision. At the same time you prevent from disturbing fingerprints on your screen. Immediately ready for use - simply turn on the pen and you can operate all applications without further installation. After 30 minutes of inactivity the pen will automatically turn into the energy-saving standby-mode. The thin tip made of PET allows smooth, continuous movements resulting in an accurate input.
  • Versatile compatibility
    Designed for both cellular phones and tablets, this stylus ensures seamless interaction across multiple devices, providing a smooth and precise experience.
  • Compact design
    The stylish and lightweight design makes it easy to carry, fitting perfectly in pockets or bags for on-the-go use.
DICOTA Active Stylus Premium - stylus for mobile phone, tablet
Stylus
Intended For
Mobile phone, tablet
Rechargeable
Run Time (Up To)
12 hour(s)
Package Content
Stylus, micro-USB cable
Product Material
Aluminium
1 cm x 1 cm x 14.9 cm
Stylus
Intended For
Package Content
Product Material
Aluminium
1 cm
1 cm
14.9 cm
Rechargeable Battery
Rechargeable
Run Time (Up To)
12 hour(s)
Brand: Dicota
