Dicota Active Stylus for iPad
Quicklinx: GX3DWS00 Mfr#: D31937
The slim and lightweight input pen fits nicely in your hand while the grip surface gives optimum hold. Follow your intuition and operate touch applications with familiar movements. Writing, drawing and navigating with highest precision. At the same time, you prevent from disturbing fingerprints on your screen.
Immediately ready for use - simply turn on the pen and you can operate all applications without further installation. After 5 minutes of inactivity the pen will automatically turn into the energy-saving standby-mode. The built-in rechargeable battery convinces with 9 hours of runtime; the status of the battery can be tracked at any time using the indicator light. The complete charging of the pen takes about 80 minutes. The 1.5 mm thin tip allows smooth, continuous movements resulting in an accurate input. Thanks to the simple replacement of the tip you can additionally prolong the service life (spare tip is included in delivery).
  • High-precision operation of touch screens
  • Accurate handling thanks to handy shape and light weight
  • Prevents from fingerprints on the screen
  • Immediately ready for use - no installation needed
  • Auto-Standby after 5 min
  • 9 h battery life (fully recharged within 80 minutes)
  • USB-C cable included
  • Replaceable 1.5 mm thin tip (spare tip is included in delivery)
DICOTA - active stylus - white
Active stylus
White
14.7 cm x 1.2 cm x 0.97 cm
10 g
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation); 10.5-inch iPad Air (3rd generation); 10.9-inch iPad Air (4th generation, 5th generation); 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad (6th generation); iPad mini (6th generation); iPad mini 5
Active stylus
14.7 cm
1.2 cm
0.97 cm
10 g
White
USB-C cable
Run Time (Up To)
9 hour(s)
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.9-inch iPad Air (4th generation, 5th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (6th generation) , Apple iPad mini (6th generation) , Apple iPad mini 5
