Devolo Magic 2 WiFi NEXT Whole Home WiFi Kit (2x LAN Pass-Thru 3x)
Quicklinx: FZ23WS00 Mfr#: 8627
  • IEEE 802.11n
19 In Stock
£223.31 ex VAT
£267.97 inc VAT
Magic 2 Wi-Fi next brings your home internet to a higher level. Thanks to outstanding Powerline technology, the full power of your internet connection is transmitted directly into any room over the electrical wiring. This turns any power socket into a potential access point for high-performance Wi-Fi. Multiple adapters connect automatically to form a seamless mesh network. This network lets you browse without interruptions and without ever losing any Wi-Fi strength. Thanks to multi-user MIMO technology, multiple terminal devices are supplied with a higher transfer rate at the same time. For maximum connectivity, Magic 2 Wi-Fi next is also equipped with two more gigabit LAN ports.
  • Powerline technology
    The internet is transmitted to any room through ceilings and walls over the electrical wiring. More reliable than any repeater!
  • Multi-user technology for better reception
    MIMO technology means that multiple end devices are provided with maximum Wi-Fi capacity at the same time. Everyone can enjoy gigabit internet simultaneously.
  • Band steering
    It uses the optimum frequency band.
  • Power save mode
    It reduces energy consumption automatically at low data traffic.
  • Two gigabit network connectors
    The two gigabit network connectors let you connect stationary network devices - such as a game console, TV or media receiver - to your internet access point over the Powerline network.
  • Integrated electrical socket
    It can be used like a normal wall socket to supply power to an additional network device or a power strip.
devolo Magic 2 WiFi next - Multiroom Kit - bridge - Wi-Fi 5 - wall-pluggable
Bridge
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2400 Mbps
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps
Auto-uplink (auto MDI/MDI-X), MAC address filtering, IPv6 support, parental control, Access Point operational mode, QoS, WPS, integrated power socket, 2T2R MIMO technology, IPv4 support, MU-MIMO technology, Airtime Fairness, Wireless Mesh support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v
AC 230V (50 Hz)
7.6 cm x 4 cm x 15.2 cm
United Kingdom
3-year warranty
Packaged Quantity
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2400 Mbps
Performance
Encryption Algorithm
WPA, WPA2, 128-bit AES, WPA3-Personal
Status Indicators
Powerline, Wi-Fi
1 x power , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Internal power supply
AC 230V (50 Hz)
8.9 watt
Devolo MAGIC 2 LAN adapter
Network cable - 2 m
United Kingdom
7.6 cm
4 cm
15.2 cm
Shipping Width
23.1 cm
Shipping Depth
9.2 cm
Shipping Height
18.8 cm
Shipping Weight
1.265 kg
Limited warranty - 3 years
10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 2 WiFi NEXT Whole Home WiFi Kit (2x LAN Pass-Thru 3x)
Brand: Devolo
