Magic 2 Wi-Fi next brings your home internet to a higher level. Thanks to outstanding Powerline technology, the full power of your internet connection is transmitted directly into any room over the electrical wiring. This turns any power socket into a potential access point for high-performance Wi-Fi. Multiple adapters connect automatically to form a seamless mesh network. This network lets you browse without interruptions and without ever losing any Wi-Fi strength. Thanks to multi-user MIMO technology, multiple terminal devices are supplied with a higher transfer rate at the same time. For maximum connectivity, Magic 2 Wi-Fi next is also equipped with two more gigabit LAN ports.
The internet is transmitted to any room through ceilings and walls over the electrical wiring. More reliable than any repeater! -
Multi-user technology for better reception
MIMO technology means that multiple end devices are provided with maximum Wi-Fi capacity at the same time. Everyone can enjoy gigabit internet simultaneously. -
Band steering
It uses the optimum frequency band. -
Power save mode
It reduces energy consumption automatically at low data traffic. -
Two gigabit network connectors
The two gigabit network connectors let you connect stationary network devices - such as a game console, TV or media receiver - to your internet access point over the Powerline network. -
Integrated electrical socket
It can be used like a normal wall socket to supply power to an additional network device or a power strip.
- devolo Magic 2 WiFi next - Multiroom Kit - bridge - Wi-Fi 5 - wall-pluggable
- Bridge
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 2400 Mbps
- Performance
- Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, IPv6 support, parental control, Access Point operational mode, QoS, WPS, integrated power socket, 2T2R MIMO technology, IPv4 support, MU-MIMO technology, Airtime Fairness, Wireless Mesh support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v
- Power
- AC 230V (50 Hz)
- 7.6 cm x 4 cm x 15.2 cm
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Bridge
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 2400 Mbps
- Performance
- Encryption Algorithm
- WPA, WPA2, 128-bit AES, WPA3-Personal
- Status Indicators
- Powerline, Wi-Fi
- 1 x power , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 8.9 Watt
- Included Accessories
- Devolo MAGIC 2 LAN adapter
- Cables Included
- Network cable - 2 m
- Localisation
- United Kingdom
- 7.6 cm
- 4 cm
- 15.2 cm
- Shipping Width
- 23.1 cm
- Shipping Depth
- 9.2 cm
- Shipping Height
- 18.8 cm
- Shipping Weight
- 1.265 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
