Devolo Magic 2 WiFi NEXT Starter Kit (2x LAN Pass-Thru 2x Plugs)
Quicklinx: FZ24WS00 Mfr#: 8619
Type: Bridge
Speed: 2400Mbps
Connectivity: Wireless, Wired
Pass-through Socket: Yes
  • IEEE 802.11n
14 In Stock
£147.91 ex VAT
£177.49 inc VAT
  • Multi-user MIMO technology: Simultaneously provide multiple devices with the best possible Wi-Fi.
  • Seamless mesh now with access point steering: Multiple Magic Wi-Fi adapters form a joint mesh WiFi network for an optimal Powerline connection of your terminal devices.
  • The fastest Internet: Over the powerline – to any power socket!
  • Future-proofed G.hn technology: Upgrade your home to the latest gigabit standard.
  • The extra LAN feature for the Wi-Fi network: Connect additional stationary entertainment devices to two additional gigabit ports.
  • Simple, expandable, secure: Create a mesh network in seconds thanks to plug and play.
Magic 2 WiFi next – High-speed Internet directly from your power sockets
Easily bring gigabit Internet into any room and experience browsing, streaming, gaming and stable home working with a mesh upgrade – the devolo Magic 2 WiFi next is the Powerline system for the whole family. The latest multi-user MIMO technology and optimised mesh ensure that all your devices at home are simultaneously supplied with unlimited Wi-Fi capacity.
Mesh Wi-Fi for more stability and convenience – that's how Wi-Fi works today
Simply enjoy a seamless connection thanks to mesh Wi-Fi. Magic Wi-Fi adapters connect to form a joint network – no manual connection, no signal interruption, no password hassle. In addition, the mesh function access point steering ensures that you always have the best Wi-Fi connection with speeds up to 1200 Mbps – without interruptions and no matter what room you're in.
Plug & play: Plug in, press the button, and experience mesh!
Build yourself a mesh network which can be expanded as you see fit, and do it in no time using Magic WiFi: Simply connect one Magic adapter to your router, plug additional devolo Magic adapters into your available power sockets and press the button to start the automatic and directly encrypted connection. The strong Wi-Fi hotspots are activated in seconds.
Use Powerline technology to distribute the Internet signal throughout your home over the power line
Magic Wi-Fi adapters use the fastest path for transmitting your Internet signal: your power line. As a result, any power socket with a Magic adapter plugged in becomes a Wi-Fi or LAN access point. Data transmission via Powerline adapter means no loss of signal quality and secure encryption without routing cables. All of our Magic adapters already have the latest generation of G.hn Powerline technology installed. This gigabit standard forms the basis of top-notch data transmission for state-ofthe-art home entertainment.
  • Powerline technology
    The internet is transmitted to any room through ceilings and walls over the electrical wiring. More reliable than any repeater!
  • Multi-user technology for better reception
    MIMO technology means that multiple end devices are provided with maximum Wi-Fi capacity at the same time. Everyone can enjoy gigabit internet simultaneously.
  • Band steering
    It uses the optimum frequency band.
  • Power save mode
    It reduces energy consumption automatically at low data traffic.
  • Two gigabit network connectors
    The two gigabit network connectors let you connect stationary network devices - such as a game console, TV or media receiver - to your internet access point over the Powerline network.
  • Integrated electrical socket
    It can be used like a normal wall socket to supply power to an additional network device or a power strip.
devolo Magic 2 WiFi next - Starter Kit - bridge - Wi-Fi 5 - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2400 Mbps
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 867 Mbps
Auto-uplink (auto MDI/MDI-X), MAC address filtering, IPv6 support, parental control, Access Point operational mode, QoS, WPS, integrated power socket, 2T2R MIMO technology, IPv4 support, MU-MIMO technology, Airtime Fairness, Wireless Mesh support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v
AC 230V (50 Hz)
7.6 cm x 4 cm x 15.2 cm
United Kingdom
3-year warranty
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2400 Mbps
Performance
Encryption Algorithm
WPA, WPA2, 128-bit AES, WPA3-Personal
Status Indicators
Powerline, Wi-Fi
1 x power , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Internal power supply
AC 230V (50 Hz)
8.9 Watt
Devolo MAGIC 2 LAN adapter
Network cable - 2 m
United Kingdom
7.6 cm
4 cm
15.2 cm
Shipping Width
11.8 cm
Shipping Depth
9.2 cm
Shipping Height
19 cm
Shipping Weight
570 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 2 WiFi NEXT Starter Kit (2x LAN Pass-Thru 2x Plugs)
Type: Bridge
Speed: 2400Mbps
Connectivity: Wired
Brand: Devolo
