Adapter set for establishing your Magic Powerline network with 3 adapters, 1x LAN + 2x Wi-Fi: Perfect for Internet that reaches all rooms and storeys for up to3 floors. More devolo Magic adapters can be added to the network at any time, of course.
The Magic 2 WiFi 6 revolutionises the Wi-Fi speed in your home! With 50 percent more Wi-Fi power than any Wi-Fi 5 PLC adapter, it reaches speeds of up to 1800 Mbps and makes this speed available to every user. Thanks to OFDMA, the channels are used with flexibility: Top-notch Wi-Fi for everyone - when sending or receiving and even when there are many users in parallel!
Your Internet signal is distributed over Powerline technology at speeds of up to 2400 Mbps, directly over the electrical wiring and to any room. An adapter turns any power socket into an access point for high-performance multi-room Wi-Fi. And multiple devolo Magic adapters connect to each other automatically to form a comprehensive mesh network.
For maximum connectivity, Magic 2 WiFi 6 is also equipped with two Gigabit LAN ports. It is the world's fastest Powerline adapter and its top-notch features make it a networking powerhouse for your home. Enjoy powerful mesh Wi-Fi throughout the home - for everyone!
50% better Wi-Fi performance than any Wi-Fi 5 PLC adapter: up to 1800 Mbps*! The latest technology of the Magic 2 WiFi 6 supplies your mobile devices with an extremely strong Wi-Fi signal.
Faster and more responsive: Simultaneous sending and receiving at lightning speed.
Extra power for lots of users: Mesh Wi-Fi for everyone - at the same time and throughout the home! Thanks to efficient utilisation of the frequency spectrum ect to each other automatically to form a comprehensive mesh network.
Efficiency boost thanks to OFDMA: Top-notch Wi-Fi for everyone - even when there are multiple users in parallel!
Powerhouse for top-notch connections thanks to WiFi 6, G.hn, MU-MIMO, AP-Steering, Airtime Fairness, Band Steering, etc.
Optimal utilisation of different spatial streams (Multi-User MIMO) enables more efficient and lower-latency data transmission for several Wi-Fi clients simultaneously.
More intelligent network management thanks to AP steering in accordance with 802.11v/k: It optimises the load distribution in more complex network topologies with multiple access points or repeaters and ensures that your devices always connect to the optimal access point.
Innovative standard: The revolution in tried-and-tested Powerline technology now available on a ground-breaking G.hn basis.
Award-winning development: Certified by the HomeGrid Forum.
Efficient work: Uses all three wires in the electricity network for high performance and stability.
Wi-Fi 6 standard for speeds up to 1800 Mbps: 4 antennae serve the Wi-Fi frequencies of 2.4 and 5 GHz simultaneously, using the full bandwidth of the entire 5 GHz frequency range (DFS).
Get off to a flying start anytime with Airtime Fairness: Faster devices have the right of way in the network.
Smart connection through band steering: Optimum use of available frequencies and channels.
Seamless reception thanks to roaming: Lightning-fast connection to the strongest Wi-Fi access point.
Secure encryption at the press of a button: 128-bit AES for the Powerline connection and WPA2/WPA3 for Wi-Fi 6.
Environmentally and cost conscious: devolo PowerSave Technology saves energy. Fully automatically.
Handy additional functions: Parental controls, guest Wi-Fi, time control settings and Config-Sync are all integrated.
4 antennae serve the Wi-Fi frequencies of 2.4 and 5 GHz simultaneously, using the full bandwidth of the entire 5 GHz frequency range (DFS). -
Innovative standard
The revolution in tried-and-tested Powerline technology now available on a ground-breaking G.hn basis. -
Top-notch Wi-Fi for everyone - even when there are multiple users in parallel! -
It optimizes the load distribution in more complex network topologies with multiple access points or repeaters and ensures that your devices always connect to the optimal access point. -
Optimum use of available frequencies and channels. -
Efficient work
Uses all three wires in the electricity network for high performance and stability. -
Lightning-fast connection to the strongest Wi-Fi access point. -
128-bit AES for the Powerline connection and WPA2/WPA3 for Wi-Fi 6. -
devolo PowerSave Technology saves energy. Fully automatically. -
 - devolo Magic 2 WiFi 6 - powerline adapter kit - wall-pluggable
 - Powerline adapter kit
- Enclosure Type
 - Wall-pluggable
- Connectivity Technology
 - Wired
- Data Link Protocol
 - Ethernet, HomeGrid
Line Properties
- Line Coding Format
 - 4096 QAM
Aerial
- Aerial
 - Internal
- Shipping Depth
 - 11.8 cm
