Devolo Magic 2 WiFi 6 add-on
Quicklinx: GL0VWS00 Mfr#: 8813
Type: Powerline adapter
Speed: 2400Mbps
Connectivity: Wired, Wireless
Pass-through Socket: Yes
  • IEEE 802.11n
Hurry, only 1 left in stock!
£141.67 ex VAT
£170.00 inc VAT
1 adapter for straight-forward expansion of your existing Magic Powerline network Perfect for boosting your connection in any room you choose. Can only be used in conjunction with at least one other Magic adapter.
The Magic 2 WiFi 6 revolutionises the Wi-Fi speed in your home! With 50 percent more Wi-Fi power than any Wi-Fi 5 PLC adapter, it reaches speeds of up to 1800 Mbps and makes this speed available to every user. Thanks to OFDMA, the channels are used with flexibility: Top-notch Wi-Fi for everyone - when sending or receiving and even when there are many users in parallel!
Your Internet signal is distributed over Powerline technology at speeds of up to 2400 Mbps, directly over the electrical wiring and to any room. An adapter turns any power socket into an access point for high-performance multi-room Wi-Fi. And multiple devolo Magic adapters connect to each other automatically to form a comprehensive mesh network.
For maximum connectivity, Magic 2 WiFi 6 is also equipped with two Gigabit LAN ports. It is the world's fastest Powerline adapter and its top-notch features make it a networking powerhouse for your home. Enjoy powerful mesh Wi-Fi throughout the home - for everyone!
50% better Wi-Fi performance than any Wi-Fi 5 PLC adapter: up to 1800 Mbps*! The latest technology of the Magic 2 WiFi 6 supplies your mobile devices with an extremely strong Wi-Fi signal.
Faster and more responsive: Simultaneous sending and receiving at lightning speed.
Extra power for lots of users: Mesh Wi-Fi for everyone - at the same time and throughout the home! Thanks to efficient utilisation of the frequency spectrum ect to each other automatically to form a comprehensive mesh network.
  • Efficiency boost thanks to OFDMA: Top-notch Wi-Fi for everyone - even when there are multiple users in parallel!
  • Powerhouse for top-notch connections thanks to WiFi 6, G.hn, MU-MIMO, AP-Steering, Airtime Fairness, Band Steering, etc.
  • Optimal utilisation of different spatial streams (Multi-User MIMO) enables more efficient and lower-latency data transmission for several Wi-Fi clients simultaneously.
  • More intelligent network management thanks to AP steering in accordance with 802.11v/k: It optimises the load distribution in more complex network topologies with multiple access points or repeaters and ensures that your devices always connect to the optimal access point.
  • Innovative standard: The revolution in tried-and-tested Powerline technology now available on a ground-breaking G.hn basis.
  • Award-winning development: Certified by the HomeGrid Forum.
  • Efficient work: Uses all three wires in the electricity network for high performance and stability.
  • Wi-Fi 6 standard for speeds up to 1800 Mbps: 4 antennae serve the Wi-Fi frequencies of 2.4 and 5 GHz simultaneously, using the full bandwidth of the entire 5 GHz frequency range (DFS).
  • Get off to a flying start anytime with Airtime Fairness: Faster devices have the right of way in the network.
  • Smart connection through band steering: Optimum use of available frequencies and channels.
  • Seamless reception thanks to roaming: Lightning-fast connection to the strongest Wi-Fi access point.
  • Secure encryption at the press of a button: 128-bit AES for the Powerline connection and WPA2/WPA3 for Wi-Fi 6.
  • Environmentally and cost conscious: devolo PowerSave Technology saves energy. Fully automatically.
  • Handy additional functions: Parental controls, guest Wi-Fi, time control settings and Config-Sync are all integrated.
    It optimizes the load distribution in more complex network topologies with multiple access points or repeaters and ensures that your devices always connect to the optimal access point.
  • Efficient work
devolo Magic 2 WiFi 6 - Add-on - powerline adapter - Wi-Fi 6 - wall-pluggable
Powerline adapter
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2400 Mbps
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Network / Transport Protocol
IPv4, IPv6
Auto-uplink (auto MDI/MDI-X), parental control, Access Point operational mode, Mesh networking, QoS, integrated power socket, reset button, timing support, PBC, band steering, SISO technology, guest access, Airtime Fairness, 2x2 MU-MIMO technology, OFDMA, WPS button, PIN code authentication
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax
AC 196-250 V (50 Hz)
7.6 cm x 4 cm x 15.2 cm
Apple MacOS, Linux, Microsoft Windows, Android, Apple iOS
United Kingdom
3-year warranty
Powerline adapter
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
2400 Mbps
Performance
IPv4, IPv6
Encryption Algorithm
WPA, WPA2, WPS, WPA3-Personal
IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, WEEE
Status Indicators
Powerline, Wi-Fi
1 x HomeGrid - power Type G , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
Internal power supply
8.2 Watt
1 x network cable
United Kingdom
7.6 cm
4 cm
15.2 cm
Shipping Width
19 cm
Shipping Depth
11.8 cm
Shipping Height
9.2 cm
Shipping Weight
584 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Speed: 2400Mbps
Connectivity: Wired
Connectivity: Wireless
Brand: Devolo
