Experience the new no-border world of surfing with all-encompassing devolo Mesh WiFi. Magic 2 WiFi streams incredibly stable, ultra-fast internet through your home at up to 2400 Mbps - and is phenomenally simple, using your power lines. Stream films in fantastic UHD. Enjoy high-speed surfing in any corner of your home. Travel in virtual realities and discover the expanse of the internet of things (IoT). Everything is possible, nothing impossible - with devolo's magical Mesh WiFi.
Welcome the digital future in your own four walls! How? With the develop Magic 2 Wi-Fi and its magical properties. It makes you ready for beyond tomorrow - today. Mesh Wi-Fi integrates all develop Magic adapters and creates a seamless network magically - for wonderful connections to the Internet in any room, on the balcony and in the garden. The Wi-Fi ac standard ensures incredible peak speeds of up to 1200 Mbps and pure, digital freedom. And without buffering of course, since the high-performance Power line technology can span extremely long distances of up to 500 metres. So streaming, gaming, home office or virtual reality are simply even more enjoyable with develop Magic 2 Wi-Fi! And static devices such as smart TVs or consoles can also be used, since they can be connected easily thanks to two Gigabit LAN connections. You can also keep a close eye on all develop Magic adapters conveniently via the innovative develop App. Thanks to super-smart Plug & Play, simply unpack, plug in and get going: non-stop magical and universal multimedia enjoyment, now and in the future - with develop Magic 2 Wi-Fi!.
Unique film enjoyment with Ultra HD streaming. devolo Magic 2 WiFi ensures that there is enough bandwidth at your disposal. Just connect your Smart TV via Ethernet cable or Wi-Fi, and off you go! Or stream the latest series on your tablet when you go to bed in the evening. The innovative Wi-Fi standard ac makes it easy.
Online gaming without limitations! devolo Magic 2 Wi-Fi prepares your for future gaming innovations as well. Fantastic transmission speeds of up to 2400 Mbps do the trick. And you can enjoy those speeds across an incredible distance of 500 metres in your house. Online or in the cloud, the gaming experience has never been so magical.
Immerse yourself in a fantastic adventure. Virtual reality allows you to be a celebrated rock star, a gutsy pilot, or a fierce Viking. It’s a pity when the experience starts to break down. When it does, it is usually because the Wi-Fi connection is weak. Get the most out of your connection with devolo Magic 2 Wi-Fi so that it never happens to you again.
Mesh WiFi all Over the House: in Your Hobby Room, the Attic, or the Garden House
Data flow along invisible channels through the house to an unprecedented range of 500 metres: From the basement to the living room, from the living room to the garden house. devolo Magic 2 Wi-Fi means that you are connected anywhere at an unbelievable transmission speed of 2400Mbps. Whether you are using a smartphone or a PC, you won’t get more surfing enjoyment anywhere! Whether you’re trying out a new trend or preparing for a future one, Magic 2 Wi-Fi prepares you optimally for whatever come.
- As if by magic, mesh Wi-Fi always connects you with the strongest WiFi access point, giving you a uniformly stable connection with speeds of up to 2400 Mbps anywhere in the house.
- Benefit from Wi-Fi ac and surf at amazing speeds at 2.4 and 5 GHz at the same time. Airtime Fairness gives fast devices right-of-way in the network, granting you added speed.
- Enchanting additional functions make devolo Magic 2 Wi-Fi something very special. Practical child safety or secure guest WiFi access, devolo Magic makes almost anything possible.
Compatibility
To date, only devolo Magic uses the innovative G.hn technology, which offers the highest transmission speeds.
Magic therefore only takes advantage of full output in a pure G.hn environment.
The simultaneous use of other PLC adapters – even those of the outstanding devolo dLAN devices – impairs performance.
- World's fastest Powerline adapter.
- With a transfer rate of up to 2,400 Mbps with latest G.hn technology.
- Techradar: "The Devolo Magic 2 WiFi series are the best powerline adapters money can buy"
- High-speed mesh home network over the electrical wiring from the German pioneer and market leader.
- Starter Kit with 2 adapters, each with 2x Gigabit LAN connections, access point.
Invisible forces are at work
Novel Mesh Wi-Fi and innovative Powerline technology links all devolo Magic adapters to an associated network and gets you seamlessly onto the Internet anywhere in the home, with the strongest connection. -
Exceeds your imagination
Surf the net wirelessly at up to 2400 Mbps! Streaming, gaming, virtual reality - and all of them magically easier, faster and more reliable than ever before. -
All-in
Connect your static devices such as smart TVs, consoles or PCs via two Gigabit LAN connections. -
The perfect solution for long distances
Easily covers large distances and always provides a strong connection, even over distances up to 500 meters. From the cellar to the attic and down to the garden - simply all through the house. -
Organizes the setup
Simply plug into the power socket - and thanks to the smart Plug & Play, the adapters connect to each other in just a few seconds
- devolo Magic 2 WiFi 2-1 - Multiroom Kit - bridge - Wi-Fi 5 - wall-pluggable
- Bridge
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid
- Frequency Band
- 2.4 GHz / 5 GHz
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, WPS, reset button, 2T2R MIMO technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac
- Power
- AC 230V (50 Hz)
- 7.6 cm x 4 cm x 15.2 cm
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.9 or later, Ubuntu 14.04 or later
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Bridge
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Max Range Open Space
- 300 m
- Encryption Algorithm
- WPA, WPA2, 128-bit AES
- Status Indicators
- Wi-Fi
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x power BS 1363 , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 12 Watt
- Included Accessories
- Devolo MAGIC 2 LAN adapter
- Cables Included
- 1 x network cable - 2 m
- Localisation
- United Kingdom
- OS Required
- 7.6 cm
- 4 cm
- 15.2 cm
- Shipping Width
- 18.8 cm
- Shipping Depth
- 23.1 cm
- Shipping Height
- 9.2 cm
- Shipping Weight
- 1.265 kg
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
