Internet from your wall socket: devolo Magic's Powerline technology enables you to enjoy a fast, stable Internet connection in any room. The Magic 2 LAN triple power socket adapter is equipped with three Gigabit LAN ports with a maximum speed of 2400 Mbps. The Starter Kit design gives you a Powerline network with the adapter. But you can also use the Magic 2 LAN triple to expand an existing network. This allows you to dispense with a LAN switch in your home office or living room.
Your powerful multi-media center
4K screens are becoming increasingly affordable. What happens next? 8K technology is already in the starting blocks with correspondingly high-resolution streaming opportunities that require very fast data transmission. -
HD-streaming
When you download a film, you don't want to wait a long time - and when you stream a film in HD resolution, it shouldn't constantly lag. -
Cloud gaming
If you game online and want to use the opportunities provided by cloud gaming, you need a fast, stable internet connection.
- devolo Magic 2 LAN triple - Starter Kit - bridge - wall-pluggable
- Bridge
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
- Auto-uplink (auto MDI/MDI-X), reset button
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- 7.2 cm x 4.1 cm x 14.3 cm
- System Requirements
- Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10
- 3-year warranty
- Bridge
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Powerline
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x power , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- 5 Watt
- Included Accessories
- Devolo MAGIC 2 LAN adapter
- Cables Included
- 2 x network cable - 2 m
- OS Required
- 7.2 cm
- 4.1 cm
- 14.3 cm
- Shipping Width
- 18.8 cm
- Shipping Depth
- 23.1 cm
- Shipping Height
- 9.2 cm
- Shipping Weight
- 810 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FSBW 051042 Condition: Customer return - item has been opened but is in excellent condition |
£92.94 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
