Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
Quicklinx: FSBWWS00 Mfr#: 8512
Type: Bridge
Connectivity: Wired
46 In Stock
£101.30 ex VAT
£121.56 inc VAT
Internet from your wall socket: devolo Magic's Powerline technology enables you to enjoy a fast, stable Internet connection in any room. The Magic 2 LAN triple power socket adapter is equipped with three Gigabit LAN ports with a maximum speed of 2400 Mbps. The Starter Kit design gives you a Powerline network with the adapter. But you can also use the Magic 2 LAN triple to expand an existing network. This allows you to dispense with a LAN switch in your home office or living room.
  • Your powerful multi-media center
    4K screens are becoming increasingly affordable. What happens next? 8K technology is already in the starting blocks with correspondingly high-resolution streaming opportunities that require very fast data transmission.
  • HD-streaming
    When you download a film, you don't want to wait a long time - and when you stream a film in HD resolution, it shouldn't constantly lag.
  • Cloud gaming
    If you game online and want to use the opportunities provided by cloud gaming, you need a fast, stable internet connection.
devolo Magic 2 LAN triple - Starter Kit - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
Auto-uplink (auto MDI/MDI-X), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
7.2 cm x 4.1 cm x 14.3 cm
Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10
3-year warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Encryption Algorithm
128-bit AES
Status Indicators
Powerline
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x power , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
5 Watt
Devolo MAGIC 2 LAN adapter
2 x network cable - 2 m
7.2 cm
4.1 cm
14.3 cm
Shipping Width
18.8 cm
Shipping Depth
23.1 cm
Shipping Height
9.2 cm
Shipping Weight
810 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
Type: Bridge
Connectivity: Wired
Brand: Devolo
