Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
Quicklinx: FSBWWS00 Mfr#: 8512
Type: Bridge
Connectivity: Wired
46 In Stock
£101.30 ex VAT
£121.56 inc VAT
Internet from your wall socket: devolo Magic's Powerline technology enables you to enjoy a fast, stable Internet connection in any room. The Magic 2 LAN triple power socket adapter is equipped with three Gigabit LAN ports with a maximum speed of 2400 Mbps. The Starter Kit design gives you a Powerline network with the adapter. But you can also use the Magic 2 LAN triple to expand an existing network. This allows you to dispense with a LAN switch in your home office or living room.
  • Your powerful multi-media center
    4K screens are becoming increasingly affordable. What happens next? 8K technology is already in the starting blocks with correspondingly high-resolution streaming opportunities that require very fast data transmission.
  • HD-streaming
    When you download a film, you don't want to wait a long time - and when you stream a film in HD resolution, it shouldn't constantly lag.
  • Cloud gaming
    If you game online and want to use the opportunities provided by cloud gaming, you need a fast, stable internet connection.
devolo Magic 2 LAN triple - Starter Kit - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
Auto-uplink (auto MDI/MDI-X), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
7.2 cm x 4.1 cm x 14.3 cm
Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10
3-year warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Encryption Algorithm
128-bit AES
Status Indicators
Powerline
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x power , LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
5 Watt
Devolo MAGIC 2 LAN adapter
2 x network cable - 2 m
7.2 cm
4.1 cm
14.3 cm
Shipping Width
18.8 cm
Shipping Depth
23.1 cm
Shipping Height
9.2 cm
Shipping Weight
810 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 2 LAN TRIPLE Starter Kit (3x LAN, Pass-Thru, 2x plugs)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FSBW 051042
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £89.66
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Bridge
Connectivity: Wired
Brand: Devolo
Stock Status: Used Stock
