devolo Magic 2 LAN: Reliable internet from your wall socket
Simply fast and fabulously flexible – devolo Magic 2 LAN means that the future belongs to multimedia. The innovative Powerline adapter brings the internet right to your home at ultra-high speed, from the basement to the attic, with amazing ease from the power socket: Just plug in the devolo Magic adapters and connect them. Intelligent Plug & Play ensures that the stable internet from the power socket will start flowing wherever you want it without complicated configuration.
What do you associate with smooth multimedia use? Do you have plans or ideas? Do you have visions of a more efficient home office on the top floor with a great view? Does your oldest child want to move into the basement with his PC and game console? Do you dream of an intelligent home cinema with everything that entails? You just need ideas! devolo will easily implement them. Its high range of up to 500 metres allows the proven Magic adapter to cross great distances with no problem, bringing stable, secure internet to any room and connects previously unreachable corners at an amazing top speed of 2400 Mbps.
Stream the latest blockbusters in ultra-sharp, brilliant 8K resolution without tiresome crashes. Immerse yourself in online gaming with adventurous, lag-free multi-player battles that feel as though you’re there. Surf YouTube channels for hours at ultra-high speed. Or would you like limitless music streaming while you do work that requires high transfer rates on your PC? The future-proof Powerline adapter does the trick! devolo Magic 2 LAN gives you the technology to do what you really enjoy.
The Gigabit LAN port allows you to connect a wide variety of stationary terminal devices, such as Smart TV, game console, or PC, to the devolo Magic adapter. Then the magical internet from your wall socket will flow right to your home network. And you remain in charge because the intuitive Home Network App ensures that you always have an eye on everything. It is intuitive and easy to use and lets you control all your adapters.
devolo allows you to live in tomorrow's world – today. devolo Magic 2 LAN, with its innovative G.hn certification, is already equipped for the future. HomeGrid Forum standardisation prepares your home network for the further development of internet-based technologies; all devolo Magic adapters are compatible with other products certified by the HomeGrid Forum. Using different adapters from devolo’s Powerline range may diminish network performance – best results are achieved with a magic only network.
To date, only devolo Magic uses the innovative G.hn technology, which offers the highest transmission speeds. Magic therefore only takes advantage of full output in a pure G.hn environment. The simultaneous use of other PLC adapters – even those of the outstanding devolo dLAN devices – impairs performance.
- World's fastest Powerline adapter.
- With a transfer rate of up to 2,400 Mbps with latest G.hn technology.
- Powerline technology for multimedia use at the highest level.
- High-speed home network over the electrical wiring from the pioneer and market leader.
- 1x Gigabit LAN port for smart TVs and game consoles or computers.
Via unseen pathways
The innovative Powerline technology gets you on the Internet anywhere in the house via the fastest and most reliable route - for a multimedia experience of the very best quality. -
Exceeds your imagination
Surf the net at up to 2400 Mbps! Streaming, gaming, home office - and all of them magically easier, faster and more reliable than ever before. -
All-in
Connect your static devices such as smart TVs, consoles or PCs via the Gigabit LAN connection. -
The perfect solution for long distances
Easily covers large distances and always provides a strong connection, even over distances up to 500 meters. From the cellar to the attic and over to the garage - simply all through the house. -
Organizes the setup
Simply plug into the power socket - and thanks to the smart Plug & Play, the adapters connect to each other in just a few seconds.
- devolo Magic 2 LAN - Starter Kit - bridge - wall-pluggable
- Bridge
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
- Auto-uplink (auto MDI/MDI-X), reset button
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 230V (50 Hz)
- 6.6 cm x 4.2 cm x 13 cm
- System Requirements
- Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Bridge
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Powerline
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x power , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 2.8 Watt
- Cables Included
- Network cable - 2 m
- Localisation
- United Kingdom
- OS Required
- 6.6 cm
- 4.2 cm
- 13 cm
- Shipping Width
- 18.8 cm
- Shipping Depth
- 23.1 cm
- Shipping Height
- 9.2 cm
- Shipping Weight
- 790 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Devolo Magic 2 LAN Starter Kit (1x LAN, Pass-Thru, 2x plugs)
