Devolo Magic 1 WiFi Starter Kit (2x LAN, Pass-Thru, 2x plugs)
Quicklinx: FSBQWS00 Mfr#: 8361
Type: Bridge
Speed: 1200Mbps
Connectivity: Wired, Wireless
Pass-through Socket: Yes
  • IEEE 802.11n
15 In Stock
£112.49 ex VAT
£134.98 inc VAT
devolo Magic 1 WiFi – the WiFi extender of the future is here.
Mobile surfing without making compromises – devolo Magic 1 WiFi brings stable internet to your home, wherever you need it, at excellent speeds. High-speed surfing on the balcony? Watching YouTube tutorials in the basement workshop? Streaming films in the garden? devolo Magic allows you to enjoy endless multi media fun in high quality. devolo Magic 1 WiFi brings you reliable Internet with ease. Just plug the magical Powerline adapter into a wall socket and have Plug & Play connect you to other devolo Magic adapters. The latest generation of devolo’s WiFi adapters brings internet to your terminal devices at speeds of up to 1200 Mbps, whether it is a PC, Smart TV, game console, tablet, or mobile. Amazingly simple – you don’t have to do anything. And to keep you from losing track of it all, the intuitive Home Network App ensures that you can keep an eye on all connected adapters from your smartphone.
The devolo Magic adapter has two Fast Ethernet LAN connections, allowing you to integrate your stationary devices into your mesh home network with ease. Its high range of up to 400 metres ensures a strong connection, from the basement to the attic, from your garage, balcony, or terrace to the garden. devolo Magic 1 WiFi uses the ac standard, operates the Multiroom WiFi frequencies of 2.4 and 5 GHz at the same time, and is what makes the excellent speeds of up to 1200 Mbps possible. For you, that means surfing at high speed and seamless streaming in HD at the same time, anywhere in the house. Airtime Fairness gives faster devices ‘right of way’ in the home network. This ensures uninterrupted streaming enjoyment without lags or crashes while your children play online games on the tablet. Simply ideal for your digital everyday life! And to make sure you don’t lose your signal on your smartphone, devolo Magic 1 WiFi works with real Mesh WiFi. The WiFi adapter ensures a gapless network and provides you with freedom – it’s up to you to use it! Transform your house or flat into a smart home or make a universal cloud work station of your PC. Build on the stable and powerful connection of the Magic home network. The latest encryption technology also ensures optimal security for your data. With ease – activated at the touch of a button – the WiFi adapter activates 128-bit AES for the Powerline connection and WPA2 for WiFi ac, whenever you need it. As one of the first adapters on the market Magic is also ready for WPA3. That is internet technology at its highest level – today, tomorrow, and in the future. Using different adapters from devolo’s Powerline range may diminish network performance – best results are achieved with a Magic-only network.
To date, only devolo Magic uses the innovative G.hn technology, which offers the highest transmission speeds. Magic therefore only takes advantage of full output in a pure G.hn environment. The simultaneous use of other PLC adapters – even those of the outstanding devolo dLAN devices – impairs performance.
  • With a transfer rate of up to 1,200 Mbps including latest G.hn technology.
  • Outstandingly cost-effective mesh Wi-Fi Magic adapter with future-proof G.hn technology.
  • High-speed mesh home network over the electrical wiring from the German pioneer and market leader.
  • 2x Fast Ethernet LAN ports, access point.
  • Easy password assignment for guest WiFi, parental controls.
  • Invisible forces are at work
    Novel Mesh Wi-Fi and innovative Powerline technology links all devolo Magic adapters to an associated network and gets you seamlessly onto the Internet anywhere in the home, with the strongest connection.
  • Fantastic performance
    Surf the net wirelessly at up to 1200 Mbps! Streaming, gaming, virtual reality - and all of them magically easier, faster and more reliable than ever before.
  • Copes easily with long distances
    Effortlessly handles extremely long distances up to 400 meters so that you always have a strong connection. From the cellar to the attic and down to the garden - simply all through the house.
  • Organizes the setup
    Simply plug into the power socket - and thanks to the smart Plug & Play, the adapters connect to each other in just a few seconds.
devolo Magic 1 WiFi - Starter Kit - bridge - 802.11a/b/g/n/ac - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, HomeGrid
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS), reset button, 2T2R MIMO technology
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, IEEE 802.11ab
AC 230V (50 Hz)
7.6 cm x 4 cm x 15.2 cm
Microsoft Windows 7 (32/64 bits), Apple OS X 10.9 Mavericks, Android 5.1, Ubuntu 16.04, Apple iOS 10
3-year warranty
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1200 Mbps
Max Range Open Space
400 m
Encryption Algorithm
WPA, WPA2, 128-bit AES
Status Indicators
Link/activity, powerline, Wi-Fi
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x power , LAN: 2 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
Internal power supply
AC 230V (50 Hz)
5.1 Watt
Devolo MAGIC 1 LAN adapter
1 x network cable - 2 m
7.6 cm
4 cm
15.2 cm
Shipping Width
18.8 cm
Shipping Depth
23.1 cm
Shipping Height
9.2 cm
Shipping Weight
890 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 1 WiFi Starter Kit (2x LAN, Pass-Thru, 2x plugs)
Type: Bridge
Speed: 1200Mbps
Connectivity: Wired
Connectivity: Wireless
Brand: Devolo
