devolo Magic 1 LAN – reliable home network via Powerline
Uncomplicated and incredibly powerful – the devolo Magic 1 LAN Powerline adapter gives you stable internet for your home via the power socket. With its long range of 400 meters, the dLAN adapter opens up rooms that previously had no network connection: Online gaming on your terrace, potter about with the help of YouTube-Tutorials in your basement workshop, or an efficient home office in the attic – there are no limits to your ideas and plans. Just plug devolo Magic 1 LAN into the power socket and connect with the other Magic adapters. Intelligent Plug & Play completes the configuration for you in seconds. The Powerline adapter immediately connects to the internet at the high speed of 1200 Mbps through your home network.
Surf at high speed, stream the latest blockbusters and series, and listen to music via streaming portals in different rooms at the same time – devolo Magic 1 LAN does the trick. devolo Magic 1 LAN gives passionate online gaming fans their money’s work, too. Immerse yourself in multi-player mode or tackle the latest gaming adventures alone with no lags or crashes. Those who prefer to be productive simply send the magical internet to their home offices. The Powerline adapter ensures that you can work securely, reliably, and at a high transfer rate.
Let yourself be inspired by the new multimedia applications – devolo Magic adapters are already made for the future. They are based on the sustainable G.hn standard and are compatible with all products certified by the HomeGrid Forum.
The Gigabit LAN port allows you to connect a wide variety of stationary terminal devices, such as Smart TV, game console, or PC, to the Magic network. However, whenever, and as often as you want. You don’t even have to give up a wall socket – each devolo Magic adapter is equipped with an integrated power socket with child safety for convenience and security. And to help you keep an eye on your home network, there is the Home Network App. It gives you an overview of all connected devices and allows you to control them intuitively and with ease via your smartphone.
The devolo Magic 1 LAN adapter is available individually or in a practical Starter Kit of two Powerline adapters. devolo Magic 1 LAN can also be used with all other devolo Magic adapters to form a home network that makes everything possible. Using different adapters from devolo’s Powerline range may diminish network performance – best results are achieved with a Magic-only network.
To date, only devolo Magic uses the innovative G.hn technology, which offers the highest transmission speeds. Magic therefore only takes advantage of full output in a pure G.hn environment. The simultaneous use of other PLC adapters – even those of the outstanding devolo dLAN devices – impairs performance.
- With a transfer rate of up to 1,200 Mbps including latest G.hn technology.
- Outstandingly cost-effective Magic adapter with future-proof G.hn technology.
- High-speed home network over the electrical wiring from the German pioneer and market leader.
- Integrated electrical socket ensures that no power outlet is lost.
- 1x Gigabit LAN easily connects static devices such as smart TVs, game consoles or computers.
Via unseen pathways
The innovative Powerline technology gets you on the Internet anywhere in the house via the fastest and most reliable route - for a multimedia experience of the very best quality. -
Fantastic performance
Surf the net at up to 1200 Mbps! Streaming, gaming, home office - and all of them magically easier, faster and more reliable than ever before. -
All-in
Connect your static devices such as smart TVs, consoles or PCs via the Gigabit LAN connection. -
Copes easily with long distances
Easily covers large distances and always provides a strong connection, even over distances up to 400 meters. From the cellar to the attic and over to the garage - simply all through the house. -
Organizes the setup
Simply plug into the power socket - and thanks to the smart Plug & Play, the adapters connect to each other in just a few seconds.
- devolo Magic 1 LAN - bridge - wall-pluggable
- Bridge
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
- Auto-uplink (auto MDI/MDI-X), reset button
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Power
- AC 230V (50 Hz)
- 6.6 cm x 4.2 cm x 13 cm
- System Requirements
- Microsoft Windows 7 or later, Apple MacOS X 10.9 or later, Android 5.0 or later, Apple iOS 9 or later, Ubuntu 14.04 or later
- 3-year warranty
- Bridge
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- Encryption Algorithm
- 128-bit AES
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x power CEE 7/4 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 3.2 Watt
- Cables Included
- 1 x network cable - 2 m
- OS Required
- 6.6 cm
- 4.2 cm
- 13 cm
- Shipping Width
- 19 cm
- Shipping Depth
- 11.8 cm
- Shipping Height
- 9.2 cm
- Shipping Weight
- 475 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 1 LAN Add-On Adapter (1x LAN, Pass-Thru)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FSBM 050340 Condition: Customer return - item has been used and shows signs of use |
£15.03 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
