Devolo Magic 1 LAN Add-On Adapter (1x LAN, Pass-Thru)
Quicklinx: FSBMWS00 Mfr#: 8289
Type: Bridge
Speed: 1200Mbps
Connectivity: Wired
Pass-through Socket: Yes
36 In Stock
£45.83 ex VAT
£54.99 inc VAT
devolo Magic 1 LAN – reliable home network via Powerline
Uncomplicated and incredibly powerful – the devolo Magic 1 LAN Powerline adapter gives you stable internet for your home via the power socket. With its long range of 400 meters, the dLAN adapter opens up rooms that previously had no network connection: Online gaming on your terrace, potter about with the help of YouTube-Tutorials in your basement workshop, or an efficient home office in the attic – there are no limits to your ideas and plans. Just plug devolo Magic 1 LAN into the power socket and connect with the other Magic adapters. Intelligent Plug & Play completes the configuration for you in seconds. The Powerline adapter immediately connects to the internet at the high speed of 1200 Mbps through your home network.
Surf at high speed, stream the latest blockbusters and series, and listen to music via streaming portals in different rooms at the same time – devolo Magic 1 LAN does the trick. devolo Magic 1 LAN gives passionate online gaming fans their money’s work, too. Immerse yourself in multi-player mode or tackle the latest gaming adventures alone with no lags or crashes. Those who prefer to be productive simply send the magical internet to their home offices. The Powerline adapter ensures that you can work securely, reliably, and at a high transfer rate.
Let yourself be inspired by the new multimedia applications – devolo Magic adapters are already made for the future. They are based on the sustainable G.hn standard and are compatible with all products certified by the HomeGrid Forum.
The Gigabit LAN port allows you to connect a wide variety of stationary terminal devices, such as Smart TV, game console, or PC, to the Magic network. However, whenever, and as often as you want. You don’t even have to give up a wall socket – each devolo Magic adapter is equipped with an integrated power socket with child safety for convenience and security. And to help you keep an eye on your home network, there is the Home Network App. It gives you an overview of all connected devices and allows you to control them intuitively and with ease via your smartphone.
The devolo Magic 1 LAN adapter is available individually or in a practical Starter Kit of two Powerline adapters. devolo Magic 1 LAN can also be used with all other devolo Magic adapters to form a home network that makes everything possible. Using different adapters from devolo’s Powerline range may diminish network performance – best results are achieved with a Magic-only network.
To date, only devolo Magic uses the innovative G.hn technology, which offers the highest transmission speeds. Magic therefore only takes advantage of full output in a pure G.hn environment. The simultaneous use of other PLC adapters – even those of the outstanding devolo dLAN devices – impairs performance.
  • With a transfer rate of up to 1,200 Mbps including latest G.hn technology.
  • Outstandingly cost-effective Magic adapter with future-proof G.hn technology.
  • High-speed home network over the electrical wiring from the German pioneer and market leader.
  • Integrated electrical socket ensures that no power outlet is lost.
  • 1x Gigabit LAN easily connects static devices such as smart TVs, game consoles or computers.
  • Via unseen pathways
    The innovative Powerline technology gets you on the Internet anywhere in the house via the fastest and most reliable route - for a multimedia experience of the very best quality.
  • Fantastic performance
    Surf the net at up to 1200 Mbps! Streaming, gaming, home office - and all of them magically easier, faster and more reliable than ever before.
  • All-in
    Connect your static devices such as smart TVs, consoles or PCs via the Gigabit LAN connection.
  • Copes easily with long distances
    Easily covers large distances and always provides a strong connection, even over distances up to 400 meters. From the cellar to the attic and over to the garage - simply all through the house.
  • Organizes the setup
    Simply plug into the power socket - and thanks to the smart Plug & Play, the adapters connect to each other in just a few seconds.
devolo Magic 1 LAN - bridge - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, HomeGrid
Auto-uplink (auto MDI/MDI-X), reset button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
AC 230V (50 Hz)
6.6 cm x 4.2 cm x 13 cm
Microsoft Windows 7 or later, Apple MacOS X 10.9 or later, Android 5.0 or later, Apple iOS 9 or later, Ubuntu 14.04 or later
3-year warranty
Bridge
Enclosure Type
Wall-pluggable
Wired
Encryption Algorithm
128-bit AES
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x power CEE 7/4 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Internal power supply
AC 230V (50 Hz)
3.2 Watt
1 x network cable - 2 m
6.6 cm
4.2 cm
13 cm
Shipping Width
19 cm
Shipping Depth
11.8 cm
Shipping Height
9.2 cm
Shipping Weight
475 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Resources
The following resources are available for the Devolo Magic 1 LAN Add-On Adapter (1x LAN, Pass-Thru)
Type: Bridge
Speed: 1200Mbps
Connectivity: Wired
Brand: Devolo
