Faster and more versatile than ever before, the devolo 9231 dLAN 650 Triple+ AV2 HomePlug Adapter is ideal for creating or extending an existing Devolo HomePlug network. Using a households electrical wiring, you can now connect up to three (3) devices that are located away from your router, at speeds up to 600Mbps. Ideal for online gaming, streaming or high bandwidth applications. To create a HomePlug network you will need a minimum of two (2) compatible HomePlug adapters.
Create or upgrade an existing Devolo HomePlug network
Using the AV2 HomePlug standards for speeds up to 600 Mbps
Three (3) integrated 10/100/1000 Gigabit LAN RJ45 Ports
The integrated power socket ensures that no electrical outlet is lost
Optimal Internet connection for computers, televisions and game consoles
Pass-Through Electrical Socket
Featuring a pass-through socket, this devolo 9231 HomePlug Adapter helps reduce any socket loss as electrical devices can be plugged directly in to the power socket on the HomePlugs facia.
3 x Gigabit LAN Ports
With the Gigabit LAN connection, you can connect an Internet-compatible device (e.g. game console, television or media receiver) to the Internet at any time via an Ethernet network cable through either one of the 3 available Gigabit LAN ports.
Standard Warranty: 3-Years
- devolo dLAN 650 triple+ - powerline adapter - wall-pluggable
- Powerline adapter - 3-port switch (integrated)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 600 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, HomePlug AV
- Power
- AC 230V (50 Hz)
- 7.2 cm x 4.1 cm x 14.3 cm
- System Requirements
- Apple MacOS X 10.6, Ubuntu, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Ubuntu (64-bit), Apple OS X 10.9 Mavericks
- Localisation
- English / United Kingdom
- 3-year warranty
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 600 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Power, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x HomePlug AV - power , 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 5.2 Watt
- Cables Included
- 1 x network cable
- Localisation
- Software Included
- Drivers & Utilities
- OS Required
- 7.2 cm
- 4.1 cm
- 14.3 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
