Devolo dLAN 500 Duo Plus
Quicklinx: 8R8XWS00 Mfr#: 9124
The dLAN Eco Line is devolo's dLAN home network product line for a particularly simple and energy-saving network at home. With the Dynamic PowerSave technology, these adapters flexibly adjust their energy consumption according to the connected device. dLAN 500 duo+ has two network ports for the simple connection of two network-compatible devices such as computers or consumer electronics, directly on the adapter. The ultra-compact design enables a flexible and unobtrusive positioning. In contrast to the classic duo model, the duo+ has an integrated electrical socket and a mains filter that improves the dLAN powerline transmission capacity even more.
devolo dLAN 500 duo+ - powerline adapter - wall-pluggable
Powerline adapter
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), integrated power socket
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV
AC 230V (50/60 Hz)
5.5 cm x 4 cm x 11 cm
Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
United Kingdom
3-year warranty
Powerline adapter
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
CSMA/CA
Encryption Algorithm
128-bit AES
Status Indicators
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
1 x HomePlug AV , LAN: 2 x 10Base-T/100Base-TX - RJ-45
Internal power supply
AC 230V (50/60 Hz)
3.5 Watt
1 x network cable
United Kingdom
5.5 cm
4 cm
11 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
