Devolo dLAN 200 AVmini Single Adapter
Quicklinx: 7DNDWS00 Mfr#: 1627
With the devolo dLAN 200 AVmini, you have the state-of-the-art powerline solution for quickly and easily networking computers and other network-compatible terminal devices over the electrical wiring.
The dLAN 200 AVmini is faster, smaller and greener than other powerline adapters. Faster, because it connects devices at up to 200 Mbps on a line length of 300 meters, smaller through its ultra-compact housing design and greener thanks to the sophisticated Dynamic PowerSave energy-saving technology, which automatically reduces the energy consumption by up to 60%.
devolo dLAN 200 AVmini - powerline adapter - desktop
Powerline adapter
Enclosure Type
Desktop
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
200 Mbps
Network / Transport Protocol
TCP/IP, CSMA/CA
Auto-uplink (auto MDI/MDI-X), integrated power socket
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV
5.8 cm x 2.9 cm x 9 cm
103 g
United Kingdom
3-year warranty
Powerline adapter
Enclosure Type
Desktop
Wired
Data Transfer Rate
200 Mbps
TCP/IP, CSMA/CA
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, Plug and Play, EN 60950, EN55022, WEEE, EN 50412
Status Indicators
Power, link OK, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM
1 x HomePlug AV - power , 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
3.3 Watt
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
5.8 cm
2.9 cm
9 cm
103 g
Limited warranty - 3 years
10 - 90%
