Connecting the best together.
The dLAN® 550 duo+ is here. In its smart design, it conceals the most innovative Powerline technology and makes your home network even easier and more multimedia-based. The fast transfer rate and powerline speeds up to 500 Mbps allow you to experience entertainment at the highest level. The range+ technology provides an even more stable Internet connection with significantly longer range.
Enjoy even more stability and mobility throughout the home. Herewith, no power socket is lost: dLAN® 550 duo+ comes with an integrated electrical socket and also offers two Fast Ethernet ports for two terminal devices. Experience the best options for your Internet with dLAN® 550 duo+ from devolo.
Your home network from the power socket. Unpack. Plug it in. Get started. The easy way to connect using your home power lines. Turn any power socket into an Internet access point.
Even higher performance and longer range with range+ technology.
The optimal Internet connection for computers, televisions and game consoles. No signal loss - stable and continuous.
Installation as easy as childs play. Just unpack it, plug it in and get started.
The two Fast Ethernet LAN ports allow you to connect two Internet-compatible devices (e.g. a game console, television or media receiver) to the Internet at any time via network cable.
With the integrated electrical socket, no power socket in your room is lost.
Rely on the Number 1 - Join the more than 10 million satisfied devolo dLAN® customers around the world.
3-year manufacturer`s warranty.
With two LAN ports for connecting network-compatible devices and the integrated power outlet, this is an ideal entry-level adapter for your home network.
- devolo dLAN 550 duo+ - Starter Kit - powerline adapter - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- Integrated power socket
- System Requirements
- Apple MacOS X 10.6, Microsoft Windows 7 Home Premium (32/64 bits), Ubuntu 12.04, Windows 8 (32/64 bits), Windows 8 Pro (32/64 bits)
- Localisation
- United Kingdom
- 3-year warranty
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- Status Indicators
- Power
- LAN: 2 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Cables Included
- 2 x network cable
- Localisation
- United Kingdom
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
