XPS 15 9520|i7-12700H|16GB|512GB SSD|15.6" FHD+|Nvidia GeForce RTX 3050|6 Cell|130W Type-C|WLAN|Backlit Kb|W11 Pro|1Y ProSpt.
Stunning display
Get immersed in content with bright, color rich panels with high resolution, with more viewing space to keep you productive. Integrated Eyesafe display technology helps to reduce harmful blue light while maintaining vivid color. Optional OLED display makes colors pop. The stunning 4-sided InfinityEdge display enables a large 16:10 screen and 92.9% screen to body ratio. -
Powerful performance to fuel creation
The XPS 15 is the perfect balance of size and performance to fuel even more intensive creative projects. Create more of what you love with a PC powered by 12th Gen Intel Core processors. Edit videos and export them faster. Use AI to help you design and broadcast at higher quality with AI effects. Dell Performance helps unlock access to four modes - quiet, performance, cool and optimized. Each mode tailors fan speeds and battery life, with performance mode unlocking the full power of your PC. -
Created for creators
XPS configurations badged with Creator Edition have been carefully selected for those wishing to cultivate their content creation skills - be it photography, graphic design, music production or beyond. Every NVIDIA GPU is backed by exclusive and free Studio Drivers that bring out the best in your creative apps. The drivers are built in partnership with app developers like Adobe and Autodesk to continually improve your experience. Proven. Reliable. And extensively tested to let you embark on your most ambitious projects. A full SD card slot makes the XPS 15 a mecca for photography by enabling rapid import of RAW images. -
Masterful craftsmanship
Using authentic premium materials, the XPS 15 is precision cut to achieve a flawless finish look. All in a durable, lightweight design where the finest details are considered and the essentials are elevated. -
Precision manufacturing
100% of the enclosure is sculpted by a CNC machining process. A high precision, machine-milled aluminum chassis creates an elegant design that's stronger and firmer than magnesium or plastic. Diamond cut sidewalls provide a scratch-resistant surface. -
Cool and light
The black carbon fiber palm rest, inspired by the aerospace industry, allow for maximum strength and minimal weight. -
Elevated essentials
The XPS 15 features a massive display, a big, comfortable touchpad and an edge-to-edge backlit keyboard with large key caps for maximum productivity.
- Dell XPS 15 9520 - 15.6" - Intel Core i7 - 12700H - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 11 Pro - Dutch / English / French / German / Italian
- Processor
- Intel Core i7 (12th Gen) - 12700H up to 4.7 GHz / 24 MB Cache
- Memory
- 16 GB DDR5 (2 x 8 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 15.6" 1920 x 1200 / Full HD Plus @ 60 Hz - 145 ppi
- Graphics
- NVIDIA GeForce RTX 3050 Ti
- Video Memory
- 4 GB GDDR6 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
- Battery
- 6-cell
- Security
- Fingerprint reader
- Silver
- 34.44 cm x 23.014 cm x 1.854 cm
- 1.92 kg
- Bundled Services
- 1 Year Dell ProSupport
- Product Type
- Notebook
- Operating System
- Windows 11 Pro - Dutch / English / French / German / Italian
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 12700H
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 14-core
- Cache
- 24 MB
- Intel Smart Cache
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM
- Speed
- 4800 MHz
- Rated Speed
- 4800 MHz
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe)
Display
- 15.6"
- Resolution
- 1920 x 1200 (Full HD Plus)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 145
- Image Aspect Ratio
- 16:10
- Image Brightness
- 500 cd/m²
- Colour Gamut
- 100% sRGB
- Anti-glare, Infinity Edge display, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, 0.18 mm pixel pitch, Eyesafe technology
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Camera
- Yes - 1280 x 720 (standard), 576 x 360 (infrared)
- Resolution
- 0.9 Megapixel (standard), 0.2 Megapixel (infrared)
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- IR/RGB camera, 78.5 degrees
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3281
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Killer Wi-Fi 6E AX1675
- Dual stream (2x2)
- Technology
- 6-cell Lithium Ion
- Capacity
- 86 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 130 Watt, 20 V, 6.5 A
Connections & Expansion
- Interfaces Details
- USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB4 Gen 3x2 (supports Thunderbolt 4, DisplayPort 1.4a Alt Mode) (Power Delivery) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Office (30 days trial, excludes office licence), McAfee Small Business Security (30 days trial)
- Silver
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- 1.92 kg
Sustainability Information
- TCO Certified
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £171.38 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Dell Upgrade from 1Y ProSupport to 3Y ProSupport - extended service agreement - 2 years - on-site | In Stock | £202.90 |
Other bundles (8)
Dell Ultrasharp U2421E 23.8" 1920x1200 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £209.52 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £33.73 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £47.93 |
Dell SB521A Magnetic Sound bar | In Stock | £36.88 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £25.00 |
Dell UltraSharp U3223QE 31.5" 3840x2160 8ms DisplayPort HDMI USB-C IPS LED Monitor | In Stock | £650.57 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
Dell Dual Monitor Stand - MDS19 | In Stock | £166.38 |
