Dell XPS 15 9550 Intel Core i5-6300HQ 8GB 1TB 15.6" Wins 10 Pro
Quicklinx: CMMGWS00 Mfr#: 03M6G
  • Core i5
  • IEEE 802.11n
  • NVIDIA GeForce GTX 960M
The extremely small 15-inch laptop packs powerhouse performance and a stunning display - all in this incredibly powerful XPS laptop.
  • Excellent display
    The virtually borderless display maximizes screen space by accommodating a 15-inch display inside a laptop closer to the size of a 14-inch.
  • Outstanding design
    Slim and lightweight, with a fast hard drive, this XPS 15 is extremely light 15-inch performance-class laptop.
  • Dazzling Full HD detail
    Choose phenomenal display technology with the Full HD display. Its high resolution allows you to see everything you do in incredibly fine detail.
  • Easy collaboration
    See your screen from nearly every angle with an IPS panel, providing a wide viewing angle.
  • Brighten your day
    With high brightness, the display is brighter than a typical laptop.
Dell XPS 15 9550 - 15.6" - Intel Core i5 - 6300HQ - 8 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (6th Gen) - 6300HQ / 2.3 GHz, up to 3.2 GHz / 6 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
1 TB HDD / 5400 rpm
Display
15.6" 1920 x 1080 / Full HD
Graphics
Video Memory
2 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
3-cell
Silver
35.7 cm x 23.5 cm x 1.7 cm
1.78 kg
Pricing Type
Build To Plan (BTP)
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6300HQ / 2.3 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (2 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Display
15.6"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 1280 x 720
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording
Sound
Stereo speakers, two microphones
Codec
Realtek ALC3266
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Killer Wireless-AC 1535 - M.2 Card
3-cell
56 Wh
AC Adapter
Input
Output
130 Watt, 19.5 V, 6.67 A
Connections & Expansion
Interfaces Details
USB 3.0 , USB-C (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack , USB 3.0 (PowerShare)
Memory Card Reader
6 in 1 (SD Card, SDIO, SDHC Card, SDXC Card, SDXC UHS Card, MultiMediaCard UHS)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Silver
Battery life Indicator
Theft/Intrusion Protection
Power adapter
Pricing Type
Build To Plan (BTP)
1.78 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
