UK/BTS/XPS 15 9500/Intel Core i7-10750H/16GB/512GB SSD/15.6" FHD/GeForce GTX 1650 Ti/FgrPr/Cam & Mic/WLAN + BT/Backlit Kb/6 Cell/W10Pro/1Y ProSpt.
See incredible detail
With high resolution, you can zoom in for great detail when editing pictures and video or see more rows and columns in your excel spreadsheet to enhance productivity. -
Thin and light
The sleek design maximizes your mobility. -
Tough stuff
The machined aluminum construction is precision cut from a single block of aluminum for a sturdy, durable chassis. -
Cool under pressure
The carbon fiber base is strong and thin like aluminum (which is why it is often used in high-performance cars) while also being lighter and cooler to the touch. -
Powerhouse performance
The XPS laptop is packed with performance features to help you stay productive and entertained, wherever you go.
- Dell XPS 15 9500 - 15.6" - Intel Core i7 - 10750H - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i7 (10th Gen) - 10750H / 2.6 GHz, up to 5 GHz / 12 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 15.6" 1920 x 1200 / WUXGA @ 60 Hz - 145 ppi
- Graphics
- NVIDIA GeForce GTX 1650 Ti
- Video Memory
- 4 GB GDDR6 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax
- Battery
- 6-cell
- Security
- Fingerprint reader
- Silver
- 34.44 cm x 23.03 cm x 1.8 cm
- 2.05 kg
- Pricing Type
- Build To Spec (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Bundled Services
- 1 Year Dell ProSupport
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 10750H / 2.6 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 6-core
- Cache
- 12 MB
- 64-bit Computing
- Chipset
- Mobile Intel WM490
- Intel Thermal Velocity Boost
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2933 MHz
- Rated Speed
- 2933 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 PCIe 3.0 x4 - NVM Express (NVMe)
Display
- 15.6"
- Resolution
- 1920 x 1200 (WUXGA)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 145
- Image Aspect Ratio
- 16:10
- Image Brightness
- 500 cd/m²
- Colour Gamut
- 100% sRGB
- Anti-glare, Infinity Edge display, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, 0.18 mm pixel pitch, Corning Gorilla glass 6, Eyesafe technology
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR6 SDRAM
- Video System Features
- Max-Q design
- Camera
- Yes - 1280 x 720 (standard), 576 x 360 (infrared)
- Resolution
- 0.9 Megapixel (standard), 0.2 Megapixel (infrared)
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- IR camera, Windows Hello, 78.3 degrees
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3281-CG
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Killer Wi-Fi 6 AX1650
- Technology
- 6-cell Lithium Ion
- Capacity
- 86 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 130 Watt, 5 / 20 V
Connections & Expansion
- Interfaces Details
- USB-C 3.2 Gen 2 (supports DisplayPort 1.4 Alt Mode) , 2 x USB-C 3.2 Gen 2 (supports Thunderbolt 3, DisplayPort 1.2 Alt Mode) (Power Delivery) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Silver
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter, USB-C to HDMI/USB Type A adapter
- BFR-free, PVC-free
- Pricing Type
- 2.05 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 110 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt | In Stock | £441.75 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £106.65 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £118.98 |
