Dell XPS 13 Plus 9320 Intel Core i7-1260P 16GB 512GB  13.4" Windows 11 Pro Silver
Quicklinx: H475WS00 Mfr#: 63G97
  • Core i7
  • IEEE 802.11n
The powerful 13-inch XPS laptop is up to twice as powerful as before in the same size. It features 12th Gen Intel Core processors and advanced battery technology, providing long battery life in a lightweight design - all for a stunning combination of speed, performance and premium mobility. Plus, dual fans are larger, providing up to 55% more airflow and in turn, enabling a more powerful system in the same size without increasing noise or temperature.
Dell Performance helps unlock access to four modes - quiet, performance, cool and optimized. Each mode tailors fan speeds and battery life, with performance mode unlocking the full power of your PC.
Work or play - you'll experience incredibly long battery life.
  • Simplified, modern, seamless
    A collection of new, edge-to-edge interfaces simplify the overall design of the XPS 13 Plus, delivering a sleek, harmonious surface. These enhanced elements also enable faster interactions, so users can create and maneuver with ease.
  • Life-like visuals, immersive sound
    Get lost in photos, movies and more with InfinityEdge displays that deliver high brightness, precise detail and vivid color.
  • Fast and secure sign-on
    A dual sensor camera separates infrared from RGB, helping you look your best, even in low light. Plus, ExpressSign-in paired with Windows Hello streamlines your login experience, detecting your presence - or lack thereof - to quickly and securely sign you in or out of your laptop.
  • Premium design
    The XPS 13 Plus was crafted with CNC-machined aluminum and glass to provide a simple, yet complete sensorial experience. Interfaces were innovated, tone-on-tone colors were added and a delicate balance was struck - all to improve efficiency and create a laptop that's thin, lightweight.
  • More sustainable than ever
    For the first time, the XPS 13 Plus is using low carbon aluminum in the chassis, thereby reducing its carbon footprint.
Dell XPS 13 Plus 9320 - 13.4" - Intel Core i7 - 1260P - Evo - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 11 Pro - Dutch / English / French / German / Italian
Platform Technology
Intel Evo
Intel Core i7 (12th Gen) - 1260P up to 4.7 GHz / 18 MB Cache
16 GB LPDDR5 (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
13.4" 1920 x 1200 / WUXGA @ 60 Hz - 169.3 ppi
Graphics
Intel Iris Xe Graphics
Keyboard Backlight
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E)
3-cell
Ambient light sensor
Security
Fingerprint reader
Silver
29.53 cm x 19.904 cm x 1.595 cm
1.27 kg
Bundled Services
1 Year Dell ProSupport
Notebook
Operating System
Windows 11 Pro - Dutch / English / French / German / Italian
Processor / Chipset
CPU
Intel Core i7 (12th Gen) 1260P
Max Turbo Speed
4.7 GHz
Number of Cores
12-core
Cache
18 MB
Platform Technology
Intel Evo
Intel Smart Cache
RAM
16 GB (provided memory is soldered)
LPDDR5 SDRAM
Speed
5200 MHz
Rated Speed
5200 MHz
Storage
Main Storage
512 GB SSD M.2 PCIe 4.0 x4 - NVM Express (NVMe)
Display
13.4"
Resolution
1920 x 1200 (WUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
169.3
Image Aspect Ratio
16:10
Image Brightness
500 cd/m²
Colour Gamut
100% sRGB
Anti-glare, Infinity Edge display, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, Low Blue Light technology, 0.15 mm pixel pitch, Eyesafe technology
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720 (standard), 640 x 400 (infrared)
Resolution
0.92 Megapixel (standard), 0.25 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
720p
Frame Rate
30 frames per second
Camera Features
IR/RGB camera, 75.8 degrees
Sound
Two tweeters, two woofers, dual array microphone
Codec
Realtek ALC1319D
Input
Keyboard, touchpad
Keyboard Backlight
Precision Haptic touchpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211
Dual stream (2x2)
3-cell Lithium Ion
55 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
60 Watt, 5 / 9 / 15 / 20 V, 3 A
Connections & Expansion
Interfaces Details
2 x USB4 Gen 3 (supports Thunderbolt 4, DisplayPort 2.0 Alt Mode) (Power Delivery)
Software
Software Included
Microsoft Office (30 days trial, excludes office licence), McAfee Small Business Security (30 days trial)
Silver
Case Material
Aluminum
Integrated Options
Security
Fingerprint reader
USB-C power adapter
1.27 kg
Sustainability Information
TCO Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
H475 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.01
H475 Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £49.36
H475 Dell SB521A Magnetic Sound bar In Stock £35.11
H475 Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.91
H475 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.19
H475 Dell Dual Monitor Stand - MDS19 In Stock £174.65
