Dell XPS 13 7390 Intel Core i7-10510U 16GB 512GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: FMMRWS00 Mfr#: 35K2N
  • Core i7
  • IEEE 802.11n
The XPS 13 webcam isn't just smaller (only 2.25 mm) - it's also better. A 4-element lens uses more elements than a typical webcam to deliver sharp video in all areas of the frame, while temporal noise reduction uses advanced noise reduction, significantly improving video quality, especially in dim lighting conditions. Finally, the lens is assembled with precise machinery to ensure all points of the image are in focus.
  • Vibrant colors
    By maximizing the color spectrum with 100% sRGB color and a 1500:1 contrast ratio, every shadow takes shape and even bright scenes gain definition.
  • Beautiful from every angle
    The anti-reflective screen combined with superior 400-nit brightness frees you to enjoy your entertainment outdoors. Plus, the IPS panel provides a wider viewing angle, so you can share your screen without missing a thing.
  • Stunning strength
    The XPS 13 is cut from a single block of aluminum, so it's more durable than a machine that's pieced together. Carbon fiber, inspired by the aerospace industry, and woven glass fiber of the palm rest, allow for maximum strength and minimal weight. Corning Gorilla Glass 4 is twice as damage resistant compared to competitive products.
  • You are the password
    The fingerprint reader integrated into the power button lets you log on with just a touch.
Dell XPS 13 7390 - 13.3" - Core i7 10510U - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i7 (10th Gen) 10510U / 1.8 GHz (4.9 GHz) / 8 MB Cache
16 GB LPDDR3 (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
13.3" touchscreen 3840 x 2160 / Ultra HD 4K @ 60 Hz
Graphics
Intel UHD Graphics
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax
4-cell
Security
Fingerprint reader
Silver
30.176 cm x 19.924 cm x 1.163 cm
1.29 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Dell ProSupport
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4.9 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
16 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
512 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
13.3" - IPS
Touchscreen
Resolution
3840 x 2160 (Ultra HD 4K)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Anti-reflective, Infinity Edge display, Wide Viewing Angle
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.9 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
CMOS sensor, fixed focus
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3271-CG
High Definition Audio, Wave MAXXAudio Pro
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Killer Wi-Fi 6 AX1650
4-cell Lithium Ion
52 Wh
AC Adapter
Input
Output
45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.2 Alt Mode) (Power Delivery) , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Silver
Case Material
Aluminum, carbon fibre
Security
Fingerprint reader
Battery life Indicator
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter, USB-C to USB 3.0 adapter
Pricing Type
1.29 kg
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
FMMR Dell Ultrasharp U2421E 23.8" 1920x1200 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £184.77
