Dell XPS 13 7390 Core i5-10210U 8GB 256GB SSD 13.3" W10 Pro
Quicklinx: FP1TWS00 Mfr#: W7HPN
  • Core i5
  • IEEE 802.11n
Dell XPS 13 7390 is a 13-inch 2-in-1 with a stunning HDR display, powerful processor and advanced performance in a thin frame, packaged in a luxurious design.
  • Revolutionary webcam construction
    The new XPS 13 webcam isn't just smaller (only 2.25mm) - it's also better. A new 4-element lens uses more elements than a typical webcam to deliver sharp video in all areas of the frame, while temporal noise reduction uses advanced noise reduction, significantly improving video quality, especially in dim lighting conditions. Finally, the lens is assembled with precise machinery to ensure all points of the image are in focus.
  • Vibrant colors
    By maximizing the color spectrum with 100% sRGB color and a 1500:1 contrast ratio, every shadow takes shape and even bright scenes gain definition.
  • Beautiful from every angle
    The anti-reflective screen combined with superior 400-nit brightness frees you to enjoy your entertainment outdoors. Plus, the IPS panel provides a wider viewing angle, so you can share your screen without missing a thing.
  • Dell's smallest 13-inch laptop
    Your entertainment can go with you everywhere - starting at just 2.7 pounds, the smaller, thinner XPS 13 is ready for take-off. So perfectly sized for airplane tray tables, you won't even notice when the passenger in front of you reclines their seat.
  • The most powerful 13-inch laptop in its class
    With up to new 10th Gen Intel Quad Core processors, more cores means increased performance, even with multiple applications running. Plus, Dell Power Manager, engineered by Dell, allows users to customize their laptop acoustics (fan speeds), temperature and performance based on their preferences between quiet, ultra-performance and cool modes. For example, quiet mode is 50% quieter than the other modes. It also dynamically delivers the maximum power from your processor while monitoring and managing system temperatures. When you see the "Engineered for mobile performance" icon next to select Dell PCs, you know it was designed to keep up with your fast-paced life.
  • Work or play longer
    You'll experience incredibly long battery life - up to 19 hours, 24 minutes on a Full HD model when using when using productivity applications like Word or Excel or up to 17 hours, 39 minutes when streaming Netflix. On UHD panel, get up to 11 hours and 24 minutes using productivity apps or up to 10 hours and 39 minutes of Netflix streaming.
  • Stunning strength
    The XPS 13 is cut from a single block of aluminum, so it's more durable than a machine that's pieced together. Carbon fiber, inspired by the aerospace industry, and woven glass fiber of the palm rest, allow for maximum strength and minimal weight. Corning Gorilla Glass 4 is twice as damage resistant compared to competitive products.
Dell XPS 13 7390 - 13.3" - Intel Core i5 - 10210U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
8 GB LPDDR3 (2 x 4 GB (soldered))
Storage
256 GB SSD - NVMe
Display
13.3" 1920 x 1080 / Full HD @ 60 Hz
Graphics
Intel UHD Graphics
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax
4-cell
Security
Fingerprint reader
Silver
30.176 cm x 19.924 cm x 1.163 cm
1.29 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Bundled Services
1 Year Dell ProSupport
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 10210U / 1.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (2 x 4 GB (soldered))
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
13.3"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Anti-glare, Infinity Edge display, Wide Viewing Angle, ±89° horizontal viewing angle, ±89° vertical viewing angle
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.9 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus, 78 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3271-CG
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Precision touchpad
Communications
Wireless
Wireless Controller
Killer Wi-Fi 6 AX1650
4-cell Lithium Ion
52 Wh
AC Adapter
Input
Output
45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort 1.2 Alt Mode) (Power Delivery) , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Silver
Security
Fingerprint reader
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
Pricing Type
1.29 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
FP1T Dell Ultrasharp U2421E 23.8" 1920x1200 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £209.52
