The XPS 13 Ultrabook is slim and features a 13.3" display cleverly fit into a footprint that's similar to an 11" laptop. XPS 13 Ultrabook feels as good as it looks, thanks to a comfort-designed keyboard and a sleek, gesture-enabled glass touch pad.
The XPS 13 Ultrabook boots from cold in as little as 12 seconds. Whatever state your laptop is in, it comes back in a snap, less than 3 seconds when it's in sleep mode and less than 5 seconds from deep sleep.
Thoughtful design
It goes beyond beauty. Machined aluminum and carbon fiber are incorporated to enhance the performance of this Ultrabook. -
Refined features
XPS 13 Ultrabook feels as good as it looks, thanks to a comfort-designed keyboard and a sleek, gesture-enabled glass touch pad. -
Sharper detail
You can experience sharper detail with twice the number of pixels than a 720p display. -
Brilliant display
The 350-nit brightness is up to brighter than a typical 200-nit panel, so movie viewing and web surfing is enhanced with exceptional illumination. -
Wide viewing angle
The full 178-degree viewing angle allows you to easily share content with friends and family. -
Turns on instantly
The XPS 13 Ultrabook boots from cold in as little as 12 seconds. Whatever state your laptop is in, it comes back in a snap, less than 3 seconds when it's in sleep mode and less than 5 seconds from deep sleep. -
Always up to date
Intel Smart Connect technology keeps your email, contacts, calendar and social networks up to date, even when your XPS 13 Ultrabook is in sleep mode.
- Dell XPS 13 9365 2-in-1 - 13.3" - Intel Core i5 - 8200Y - 8 GB RAM - 256 GB SSD - with 1-year ProSupport
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) - 8200Y / 1.3 GHz, up to 3.9 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3
- Storage
- 256 GB SSD
- Display
- 13.3" touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 615
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell
- Security
- Fingerprint reader
- Silver
- 30.42 cm x 19.85 cm x 1.37 cm
- 1.24 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year
- Bundled Services
- 1 Year Dell ProSupport
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8200Y / 1.3 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
- Rated Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 13.3"
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Infinity Edge display
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Resolution
- 0.92 Megapixel
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 74.6 degrees
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3271
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Technology
- 4-cell Lithium Ion
- Capacity
- 46 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 30 Watt
Connections & Expansion
- Interfaces Details
- USB-C 3.1 (supports DisplayPort Alt Mode) (PowerShare) , Thunderbolt 3 (PowerShare) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC UHS)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Silver
- Security
- Battery life Indicator
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- Pricing Type
- 1.24 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Dicota Privacy filter 2-Way for Laptop 13.3" Wide (16:9), side-mounted | In Stock | £26.84 |
Kensington Clicksafe Combination Lock - Security Cable | In Stock | £34.44 |
Other bundles (3)
Dell Slim DW316 USB External DVD Drive | In Stock | £35.33 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £10.03 |
Dell KB-813 Smart Card Reader | In Stock | £37.91 |
