Dell X1026 Switch L2+ Managed 24 x 10/100/1000 2 x Gigabit SFP
Quicklinx: BTTXWS00 Mfr#: 210-AEIM
The intuitive graphical user interface (GUI) of Dell Networking X-series switches makes setup and management simple for network administrators. Based on extensive usability testing, the design of everything from navigation to menu structures and help tips is inspired by the way IT professionals think and work, making the interface a pleasure to use regularly or occasionally.
Pick the right switch for your network. Choose from a broad selection of models with rich feature sets and a variety of port counts. Power over Ethernet (PoE) and PoE+ models provide additional deployment flexibility, allowing you to connect, auto-configure and power phones, cameras, compact switches and other network devices.
Dell Networking X1026 - switch - 24 ports - Managed
Switch - 24 ports - L2+ - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x Gigabit SFP
Performance
Switching fabric bandwidth: 52 Gbps , Forwarding performance: 38.7 Mpps
MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 4 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
20.9 cm x 25 cm x 41.25 cm
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Authentication Method
RADIUS, TACACS+
24 x 1000Base-T , 2 x Gigabit LAN SFP , 1 x USB Type A management , 1 x micro-USB management
Internal power supply
Power Provided
40 Watt
21.5 Watt
20.9 cm
25 cm
41.25 cm
Limited warranty - lifetime
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BTTX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
BTTX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.76
