Wyse thin clients are built for easy integration into your VDI or web-based environment with instant, hands-free operation and performance that meets demands.
Easy to start, easy to use
Get up and running fast with certified trouble-free deployment, no matter which broker environment you choose. -
Ultimate configurability
Connect in all the ways you need to with a wide variety of mounting, display, wireless and wired connectivity options. Plus with expansion slots and forward-looking features, your setup easily addresses all your needs. -
Enhanced security
Keep apps and data-sensitive content safe with a secure data center and embedded protection.
- Dell Wyse 5070 - DTS - Celeron J4105 1.5 GHz - 4 GB - flash 16 GB
- Thin client - desktop slimline
- Bundled Services
- 3 Years Dell Collect and Return Service
- Processor
- 1 x Intel Celeron J4105 / 1.5 GHz (, up to 2.5 GHz, (Quad-Core)
- Cache Memory
- 4 MB
- Cache Per Processor
- 4 MB
- RAM
- 4 GB DDR4 SDRAM
- Hard Drive
- Flash 16 GB - eMMC
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 600
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Wyse Thin OS
- Black
- 3.56 cm x 18.4 cm x 18.4 cm
- 1.2 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - pick-up and return
- Thin client
- Bundled Services
- Product Form Factor
- Desktop slimline
- Built-in Devices
- Speaker
- Black
Processor / Chipset
- CPU
- Intel Celeron J4105
- Clock Speed
- 1.5 GHz
- Max Turbo Speed
- 2.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total)
Hard Drive
- Flash - eMMC
- Capacity
- 1 x 16 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Input Device
- Mouse (on selected markets only)
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- Wake on LAN (WoL)
- 2 x USB 2.0 (2 in front) , 5 x USB 3.0 (1 front, 4 rear) , 1 x USB-C 3.1 (1 in front) , 2 x DisplayPort , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out
- Included Accessories
- Vertical stand
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, DisplayPort 1.2a
- Pricing Type
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Wyse Thin OS
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 3.56 cm
- 18.4 cm
- 18.4 cm
- 1.2 kg
- 0 °C
- 40 °C
- 20 - 80%
