Advanced performance - higher quality
The Wyse 5030 PCoIP zero client is a fully functional endpoint for VMware and Amazon WorkSpaces that delivers a true PC-like experience and offers the full benefits of an efficient and secure centralized computing environment, with dual display support, multimedia playback, HD audio and four USB ports. The dedicated hardware PCoIP engine delivers rich multimedia, high-resolution 3D graphics, high-definition media, and full USB peripheral interoperability locally over a LAN – or remotely, -over a WAN. Optimized compression algorithms operate in real-time to achieve the best possible image quality for the available network bandwidth. -
Secure centralized computing environment
No locally-embedded OS, resulting in “zero attack surface” means that the Wyse 5030 PCoIP zero client is resistant to viruses or malware. As true zero clients, these devices require zero configuration and management. -
Cool, quiet work environment
Extremely compact and energy efficient, the Wyse 5030 PCoIP zero client draws under 9 Watts of power– creating cooler, quieter working environments.
- Dell Wyse 5030 - DTS - Tera2321 Tera2321 - 512 MB - flash 32 MB
- Zero client - desktop slimline
- Bundled Services
- 3 Years Dell Collect and Return Service
- Processor
- 1 x Teradici Tera2321 Tera2321
- RAM
- 512 MB DDR3 SDRAM
- Hard Drive
- Flash 32 MB
- Optical Storage
- No optical drive
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Black
- 17.7 cm x 11.6 cm x 2.9 cm
- 480 g
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 3 years
- Zero client
- Bundled Services
- Product Form Factor
- Desktop slimline
- Black
Processor / Chipset
- CPU
- Teradici Tera2321 Tera2321
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 512 MB
- Technology
- DDR3 SDRAM
Hard Drive
- Flash
- Capacity
- 1 x 32 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- DVI, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
Input Device
- Mouse (on selected markets only)
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- 4 x USB 2.0 (2 front, 2 rear) , 1 x DVI-I , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x DisplayPort , 1 x headphones/microphone
- Included Accessories
- Horizontal feet
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power adapter
- Nominal Voltage
- Power Provided
- 30 Watt
- 9 Watt
Operating System / Software
- OS Provided
- 17.7 cm
- 11.6 cm
- 2.9 cm
- 480 g
- 10 °C
- 40 °C
- 10 - 95% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.72 |
