Thin client for virtual desktop environments also serves as a powerful yet compact cloud desktop.
Strong and compact
The Wyse 5000 series thin client is a highly-efficient and powerful endpoint platform for virtual desktop environments. With its extremely compact size and high performance, it's a versatile virtual desktop endpoint. -
High-performance multimedia
Need to deploy a dependable platform to display, manipulate and work with high-definition multimedia, voice and video in a virtualized environment? The 5000 series thin client delivers stunning performance and display capabilities across 2D, 3D and HD video applications. As such, it supports a broad and diverse range of user, application and operating requirements. -
Highly scalable, easy to operate and manage
IT administrators won't need to visit or touch cloud clients to manage them. The 5000 series thin client can be managed remotely that lowers the total cost of ownership for large deployments and offers remote enterprise-wide management that scales as you grow from just a few to tens of thousands of cloud clients. -
Environmentally conscious computing without compromise
The silent diskless and fanless design helps reduce power usage. Dell is committed to helping you implement a computing strategy with a lower environmental impact that offers an efficient and productive computing experience by significantly reducing energy usage and heat generation.
- Dell Wyse 5010 - DTS - G-T48E 1.4 GHz - 2 GB - flash 8 GB
- Thin client - desktop slimline
- Bundled Services
- 3 Years Dell Collect and Return Service
- Processor
- 1 x AMD G-T48E 1.4 GHz (Dual-Core)
- RAM
- 2 GB (installed) / 4 GB (max) - DDR3 SDRAM
- Hard Drive
- Flash 8 GB
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 6250
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Wyse Enhanced SUSE Linux
- Black
- 4 cm x 18.5 cm x 17 cm
- 930 g
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Thin client
- Bundled Services
- Product Form Factor
- Desktop slimline
- Built-in Devices
- Speaker
- Black
Processor / Chipset
- CPU
- AMD G-T48E
- Clock Speed
- 1.4 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 2 GB / 4 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
Hard Drive
- Flash
- Capacity
- 1 x 8 GB / max 8 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DVI, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
Input Device
- Mouse (on selected markets only)
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- 1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone , 1 x DisplayPort
- Included Accessories
- Vertical stand
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- 8 Watt
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 4 cm
- 18.5 cm
- 17 cm
- 930 g
- 10 °C
- 40 °C
- 10 - 95% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
